Just flashed and am running it now on backside
Thank you for testing. I have just updated the package to enable the OBEX FTP protocol on the server side.
Not sure I can be a huge help all I mainly use bt for is file transfer with my wife's cm7 ov
I need testers for my kernel changes. I have backported the android drivers from 2.6.38.8 and all of the fixes for bluetooth stack and drivers from the 2.6.32.59 kernel. It seems to be working fine based on my preliminary testing. Can you please test and let me know if you find any problems/change with overall performance and bluetooth use? You can find all changes here.
Thanks in advance if anybody wants to help.
I noticed that I get a Wi-Fi error with this kernel. Running iwconfig in the terminal shows no wireless extensions.
The wireless module is included. Wifi and iwconfig works here. What is that WiFi error?
How in the hell do you disable the transparent statusbar? It's extremely annoying, and the only reason I don't use this ROM.
I'm not sure what the error is. It just says error in the Wi-Fi settings menu.
Is there a log file I could check.
I guess it was a bad flash. Wi-Fi is working now:-[
I have new build https://github.com/inferiorhumanorgans/android_device_lge_thunderc_common/wiki/Binary
Changelog
5-20-12:
- sync'd up with CM
- Fixed: Baseband Version - Thanks to mrg666
- Fixed: Blue-Tooth MAC address - Thanks to mrg666
- Kernel v4: 1) Updated to LG's ZV9 kernel source 2) Changed to SIO scheduler
Special thanks to Blarf, Jerry, mrg666, thekarven, TDM and all the others that have help to improve this project.
Enjoy!
Bob
Late to the party, but I've been running the new kernel now for about an hour testing Bluetooth performance and it's great.
On another note, the only way I know to get a reboot so far is to run navigation with the newest Maps. (6.7.0) and drive around for a bit.
I get reboots using former and new mirage kernel + bobZhomes kernel, it could easily be the app. (I thought for a bit it may be the phone was overheating, but I've kept a closer eye on the temp using some battery app temp meter and it reboots even when cooler.)
I might do a clean wipe, and install Maps only to see if it persists. But I'm fairly confident I'll experience again since it's become my final test for stability due to this.
CM 7.2 is still at RC1, see here: https://github.com/CyanogenMod/android_vendor_cyanogen/blob/gingerbread/products/common_versions.mkAwesome, been waiting for this!! Downloading now!! Won't it be rc 2 for Cm7.2?
