[ROM+Kernel] Inferior Human Organs unofficial CM7.1
I was wondering the same thing... :(
Sent from my A200 using Tapatalk 2
Jerry won't be releasing anything until he figures a way to stop downloads from unknown sources from starting without a prompt. He is right, its a very valid problem, and I hope he can figure something out.
sent from my Nokia 5110
Hopefully if he fixes it, Google will acknowledge him and/or compensate him
Sent from my LS670 using Tapatalk 2
I have question concerning Bobzhome's 5-20 build. Now I believe I've flashed one of his earlier builds before without noticing this. I have an ex4 partition on my sdcard and when I flashed Bob's newest build I noticed I had way too much room left after restoring my apps. So I did a df -h and lo an behold my data/app and dalvich cache are on it. Now I don't recall flashing any link2sd scripts. Sorry if this is obvious noob but is this normal? Thanks in advance. I read his changelog and I seen where starting with his 3.7 kernel that there was support for link2sd but I assumed you had to manualy ad script. Anyway it is an unexpected plus!
Can someone help me change the default signature that is displayed when I send a text to email. The current signature is: "Sent from my mobile. Enjoy". I am using the backside ROM and I am not using a 3rd party messaging app. Thanks
This has to be something virgins system adds when converting your text to email. I see no way in messaging app or on phone to edit this.
if its yahoo mail,try deleting the signature they allow you to change. they could be inserting it after it reaches the inbox.
edit: also,if it persists(which i think it will because you are sending from your phone number directly to mail) try using a 3rd party mail app like k-9 and just copy/paste texts,etc to it and send to your account. other than those options i dont believe the mobile signature can be removed.
Thanks for reminding me!
I did add a script to move apps and dalvik to your EXT partition(if you have one).
It's needed with ICS, because of ICS eating up so much space...so I added it to my GB ROM, so that I could also access my apps.
I might have to take your rom for a spin for this feature alone thanks :-) any plans on including the backside updater in your rom?
Jerry did generously offer the IHO builders the use of his updater...but I declined since I don't see many more builds coming from CM7.2
Your probably right about there not being a lot more updates to cm7.2 it still would be a convenient way to switch between builds.... The more roms that use it would make it almost like rom manager but better and just for the ov.
BobZhome, your latest ROM is causing my phone to reboot, it is not all the time and it is not frequently, I will say once a day, I like your ROM by the way. Lately I having issues using my phone at work loosing the signal and yours fixed that. I moved to Harmonia which also is very stable at work. Just wanted you to know.
Of course I'll leave it to Bob to provide a definitive response to this.
But with something like this, the first thing I would try is disable any overclock for a day or two (or drop it to 480-600). If that solves it, you KNOW with great certainty that your current clock speed exceeds the phone's tolerance and to drop it a notch or two. (Of course if you're not OC'ed, just ignore this post).
Many people seem to believe that certain ROMs allow their phones to OC faster, because they don't reboot or otherwise visibly misbehave. Reality is the phone's OC tolerance is purely based on individual hardware, and no ROM can change that on a hardware level.
It is true that some ROMs may run the phone harder (and hotter) and thus trigger errors. The harder a CPU works, the more power it draws, the hotter it gets and the less stable it becomes. The same would be true with some apps. But mostly, it is complete coincidence whether an OC triggered CPU error causes one ROM to FC or reboot, while another ROM gets by without noticeable problems. The error was still there regardless on both ROMs (given the same clockspeed, temperature etc).
The exception is when the CPU shuts down to protect itself from frying, that is NOT a coincidence :D
At least this is how computers work, I assume these phones are the same.
I am not suggesting you shouldn't overclock (I OC both my phone and my computers). But whenever I install a new ROM, I disable overclock while I perform basic tests, until I see that it is stable. Otherwise I don't know if I am testing the ROM or my OC. Similarly, I disable OC when I perform backups and other data sensitive tasks -- say, downloading a flashable zip for which I don't have an MD5.
Once again, just disregard this if you aren't overclocked or already tried disabling it. I've been on this soapbox before, and the message wasn't very popular, so I'd better step down :o
Reactions: BobZhome
Is random freezing leading to rebooting 1-3 times a day normal for other BACKside users? I have 0502 and this happens. :/
Most likely this is due to the ics screen rotations. Go into settings-cyanogenmod settings-display and uncheck rotation animations then reboot
MadeliWashi
