[ROM+Kernel] Inferior Human Organs unofficial CM7.1
ok so im back to BACKside this is the first time i have used it since Build 07212011 where I found the charging issue. But not it seems to be working just great even custom ringtones and thats a + ty big J
After flashing asop's recovery (the one that blarf uses) and flashes the latest build. Just about all my issues are gone.
You should always use the same recovery as the dev and maintainer of your Rom. It would have saved me so much time if I had the right one from the start.
I use the recovery from Rom Manager(the newest CWRM) and It works great
I have the wifi problems and im also using a belkin router n600. i wonder how many of us having this pro blem are using a belkin router?
I just flashed Build 08032011 today @ work and we have a belkin n300 and it works great. I have a Touchstone Cable Modem @ home and when I try it I will report back
Only one thing I'm going to say about this, then I expect the issue to be dropped.
He said he was going to be more active at XDA, known to be a developer's forum. This is where developers exchange ideas and code to make all ROMs better. It can only bring good results, it is not a smear of AC forums in any way.
Fine fine, do your bestest blarfie
Sent from my Optimus V
With this build I seem to have less problems with wifi and words with friends. Great work guys. Keep it up. :D
I asking had the n300 before I switched to the n600 and everything worked great. On the n600 I'm getting a lot of moments were my connection is incredibly slow so I guess it just different for different routers
I'm on both forums, so its cool that blarf is sticking to one forum, I don't blame him one bit, we are annoying.
On drew's rom he added a rom updater through the android settings on the phone, it seems like a good idea, you should check it out jerry
Reactions: JerryScript
Bob's build looks good too. So many builds now I'm indecisive :/ been using Jerry's exclusively and loving it
I finally updated to backside and I love it! Even tho it took me a lil longer to get it set up its running pretty smooth now my really only biggest complaint is that I can't get honeycream theme to work with it I dunno if it is my phone specific because I have had weird problems but its only a little sacrifice I haven't had any issues with wifi at all
Is there a setting to allow ringtones and notifications to sound out from the handset while the headset is plugged in? I forgot to unplug the headset today and missed a couple of calls since I didn't have the headset in my ears. This works fine on froyo based roms.
Pull up the cmsettings menu and look under sound, scroll down ;)
I enabled ringtones, alarms and notifications to play through the speaker and all of them still play through the headset. No sound from handset.
piikea
