[ROM+Kernel] Inferior Human Organs unofficial CM7.1
So which is best in performance and battery life? Backside or bobz cm7? Do they have the tws bug? I think the tws bug was only in froyo?
omy this rom idk if its just luck or somehting but my battery lasted 1 day and 10 hrs. :O and i had wifi and 3g on and played my fav. game aliens and constant facebooking.... omy... :))))))
I have just noticed that my phone only vibrates when somebody calls me but my ringtones make no sounds. This only happened recently after I did a complete wipe and installed the latest IHO version (8/3). I have looked at sound settings, etc. and cannot find how to get the ringtone to work during a call. When I set the ring tones in settings they make sounds, but when I get a call I only get vibration. It is probably something simple. Other sounds seem to work.
Can you please post the battery use statistics and TWS?
I had no TWS. I was at work for 3 hours with my phone in my pocket the whole time. I get great signal there.
My statistics were 50% cell standby and 49% phone idle.
Spare Parts showed no apps that were keeping the phone awake. I don't have any "crazy" apps installed. Just the basics. The only apps (aside from Google Apps) that update in the background are Facebook and WeatherBug every 2 hours. I have no problem with them on Harmonia.
WiFi and Bluetooth were off. I never toggle GPS, so that bug shouldn't be an issue.
I just don't have any luck with CM7 ROMs on my OV. They always give me terrible battery life. But Harmonia has always allowed me to last through a day with some left over with moderate use.
Thank you for the feedback. Let me check what I get comparing with you. I have flashed a plain vanilla IHO straight from the repository last night (i.e. built myself) after cleaning everything.
If anybody wants to try, you can download at the following link.
www.mediafire.com/?g0uadldevypgknp
MD5 sum: C58E13AB23AF1C13C9D30D3C44F9277D
Reactions: arhtard
VM670-CM-7.1-RC1-IHO-KANG-08052011.zip
So I edited the OP to direct everyone to the wiki for the latest builds. You're welcome to edit the page and add your build info.
Reactions: mrg666 and Whyzor
Hey does anyone know what would be involved to port these over to the M? I've got a buddy who went with MetroPCS after I showed him my V and I'd like to be able to hook him up with all the goodies I've been bragging to him about.
Have him sign up at xda and PM Blarf, he will give him instructions on how to help port it to the M. ;)
Basically, we have to determine the partition layout (should be similar), and he'll need to extract some blobs for Blarf to add to the repo. This all assumes the basic framework and kernel are similar.
If I use lg phone tools o flash my girls phone back to stock will that be good enough for the optimus m?
I flashed the Inferior Human Organs Recovery v4.0.1.4 and now the Settings, Home and Power buttons don't do anything when the phone is booted in the recovery mode. When any of those buttons is pressed, a ClockworkMod logo appears. Is there any way all functions (esp wiping system, data, cache, installing zip files) in the recovery mode through adb?
Thank you.
Thank you.
I am using 3.2.0.1 and the buttons are assigned as follows. Scroll with the sound buttons up and down, select with the camera button, and use back button to go back. It is probably the same with 4.0.1.4.
Thank you.
As stated above yes the camera button is used to select "enter".
____________________________________
blarf mentioned remapping the button back to the home or menu button. IMO leaving it as the camera button would be the best idea. It keeps consistency with the various phones and recoveries. Most phones have a camera button or atleast a third side btton other then the power button. But hey Im just a user once I figure this out I can build a recovery however I want :D.
I'm using mrg666's rom (got it from XDA, its on github https://github.com/inferiorhumanorgans/android_device_lge_thunderc/wiki/Binary)
And man do I love it, EVERYTHING works perfectly, battery life is awesome, headsets work great, MMS, I still haven't tried the bluetooth though, the camera is fine, etc. Haven't had an issue yet. Thanks guys<3
i'm using the same...
all i can say is WOWWW.
this is so smooth and flawless, been messing with it for about 6 hours now.
haven't found 1 problem or issue or hiccup, trust me, i have been trying to, lol
only thing i haven't been able to check is bluetooth, but i don't use it anyway
running as smooth as Harmonia 1.3.
AMAZING work guys!
THANKS to all of you for your continued development on this!
imo it should be a final candidate...
its to a point where i won't check in everyday, if at all now, for an update or new release
this is my new "rom of choice"
thumbs up and 4 stars!
Reactions: itsrayray
i have a suggestion for the next update how bout the camera and the lighting can it be back to normal??
I have tested the battery use today. Charged to 100% and left the phone at a place with good signal for 2 hours and 30 minutes. Wifi, GPS, sync, etc were all on but GPS was off. The battery level went from 100% to just 99%. I am using 08062011 build of IHO right now. Just for Maps 5.8, I have also installed ATK to avoid it running in the background and eating my battery.
romanjona
