[ROM+Kernel] Inferior Human Organs unofficial CM7.1
What's your overclock set to? The number one cause of camera crashes is too high of an overclock.
I just tested the button to be sure there wasn't an issue, the camera started up fine three times in a row.
thanks jerry. it was an app that was causing this crash. latest build connects faster via wifi and way less bloatware . thank you all IHO devs
Reactions: JerryScript
The battery life on this build is the best I've seen on CM7 in a while. Great job Blarf! Also, Jerry, the wifi patch included in the 8/10 build fixed my issues.
Is anyone else unable to set live wallpapers with the new 8/10 build of BACKside?
His newest build had live walls picker taken out so will have to wait for the next release our put it back in yourself.
Yeah gotta love middle of the night editing. LOL.
I have a folder full of audio clips that Ive edited and yeah it helps me remember not to get involved in remastering stuff past midnight. 4.5gb of 30 second clips...One of theses days Im going to mash them all together.
How would i do that, is it easy or would i be better off waiting for the next release?
Backside is great. Thanks for all the hard work guys. I do have a little issue though its not with the rom I was hoping you could help. The new market sucks and I can't stand it and if you replace it with the old one it just auto updates again. So the question is can you put the old one in and make it where it wont update to the new one.
just finally flashed the 8/10. wifi seems to be waaaaaaaaaaaaaaay less finicky than it has been. works way better.
for some reason every time i flash a updated version i ALWAYS forget to follow up with green machine theme. ( <---- absolutely love it.) lol. always have to go back and flash it.
the build has gone a LONG ways. and i have loved every bit of it. And look forward to where it is going! :D
Thanks All!
Uninstall the market updates then use Autorun Manager and disable the market updater reciever.
I don't like the new market either, way to windows7phonish for me. Unfortunately, the market self updates. :(
I know there are others too, but PLEASE FOR THE LOVE OF ANDROID file a bug report. Tell google you dont like the style. If enough people do this then they will get the hint.
im now the proud owner of one of the sexiest IHO optimus V in the world ..... sort of.
what do you guys think ? almost all backgrounds look great with the transparent top bar :D
im trying this one out, it has a 3d feel to it when you transition screens
thanks to IHO devs for all their hard work!
and of course UOT !
and of course UOT !
Sweet how did you get the files needed for the transparent status, I never can download the patch
First of all thanks to all devs here for the great work. Keep it up.
One quick question...this has been bugging me for a while.
I have data2ext 4 set up with an ext 4 partition. Everytime I want to install a rom or update on using the cwm or iho recovery and do a full wipe it messed up the ext 4 partition. So I need to repartition the whole sd card again.
Is there an easier way to do this? Thanks everyone for the help and you guys rock
ty . just go to UOT and upload your framework, SytemUI.... and edit in 'status bar' and set it to a color..
any color you want ' i went black' .. and then set how transparent % you want :D
chrisra
