[ROM+Kernel] MiRaGe-CM7.2-IHO (07132013)
Re: [ROM+Kernel] MiRaGe-CM7.2-IHO
After a full wipe and clean install of the 9/30 build, I cant get instagram to install. The market says its incompatible.... anyone else having this issue?
I've had it. I side loaded it and afterwards it never had a problem. Check the MD5 of the rom zip.
If your toggling between wifi and 3 G use 1 or the other with a good connection to get the download properly , then try flashing it again over right what you have
I had the same instagram problem. Here's how to solve. Get on the play store with a computer and install instagram through there.
I've flashed the rom. But nothing from the play store will download when I'm connected to wifi.
Also what should I put the CPU settings at?
The OP reccomends something along the lines of 122-806 interactive.
I use 806-245 interactive or sometimes 787-122 performance when I need to stream with low coverage or something.
I'm running 806-600 interactiveX stable no reboots I'm using Bobz kernel though...
Sent from my LG-LS670 using Tapatalk 2
Decided to time a boot up on this phone running the latest build of MiRaGe.
3 minutes and 26 seconds.
O_O
Any suggestions on trimming that down? :D
Does the built-in CM7 hotspot not work on this? I was able to connect the device, however, there was no internet connection.
Is your phone bill paid.
You may need to reactivate using froyo
Hi,
I haven't tried Mirage yet, I am on Harmonia 2 right now. I have a couple of questions:
1/ Speed and stability wise, how do both ROMs compare? I assume they should be very similar since (if I got it right) Harmonia 2 is based on Mirage
2/ Can I install Mirage on top of Harmonia 2? (clearing just the caches). Or, should I format the system partition and reinstall apps?
3/ Harmonia 2 has the following audio related issue: when connecting the audio jack (for example to a car's aux in), it is possible to control the volume for media play but not for voice calls; audio for voice calls is too low. I was told that this is an IHO issue, not introduced (and not fixable) by Harmonia. Does anyone know if the same issue exists in Mirage?
Thanks in advance for any help!
Based on some research, it appears there's a bug when dialing contacts with a + sign at the beginning of the phone number. This leads to a "call has been lost" screen. This bug is mainly related to CM7. I am always traveling internationally and it would be a pain to have to remove the + from all of the numbers. Is this something that can be fixed? Thanks
Anyone else not able to download via the rom mediafire link?
MD5 matches my file. The play store just finds my android version incompatible with instagram, I dont have the option to install it. Ill get it another way.
Hmm.
I defeated that by taking a backup of Instagram from my wife's phone. After installing the apk it worked just fine. Also I receive updates from Google Play.
1. They're both similar, but Mirage is better overall in terms of speed and responsiveness, as it's updated more frequently.
2. You probably could try that, but I've never done it. I'd think it's still safer to do a nandroid backup, then a complete wipe, then install Mirage. If you backup your apps using Titanium, it'll be easy to reload them, though it might take at least 30 minutes or so if you have more than 50 apps.
3. Yes, this is an IHO issue. If your media volume is at least halfway, phone call volume should be loud enough, esp. through car speakers.
I like Mirage better than Harmonia, because of the tweaks that mrg666 implements to his ROM.
Hi,
mama baer
