[ROM+Kernel] MiRaGe-CM7.2-IHO (07132013)
Re: notifications awol
I'm assuming you checked the settings already?
EDIT: I didn't mean to sound condescending or anything. Sorry!! :(
Can anyone offer any advice how to get my notifications working? Gmail comes through, but not anything else like Sportacular or Words. I'm on the 0930 build.
Yeah, you'd havta go into each individual app and check settings and apply notification sounds and whatnot ...
This usually has to be done after a new flash and/or update;)
As mentioned, not a ROM issue in MiRaGe 4 sure!
SOLID!! :)
Re: [ROM+Kernel] MiRaGe-CM7.2-IHO
Going to start using this ROM. Hopefully I won't run into the many errors I did with some of the other ROMs I tried!
You really shouldn't have any problems. This thing is rock solid and super stable yet very customizable and tweakable. Thanks a million mrg666
tap tap tap
Great ROM thanks a lot. Is there an easy way to change the boot logo (not boot animation)?
Do you mean the black LG logo screen? To my knowledge, there's no simple way to change it. I believe its stored on its own partition, actually.
Having issues with the 9/30 build. It not letting me receive calls at all.. is there any way for someone to post a link to the 7/7 build? That one I had no issues with.
Love mirage and have used it for the bigger part of a year. Never had an issue like this before so its odd this should happen now.
How about the 7/16 build? That's the earliest one that I have...
VM670-CM7.2-IHO-07162012_MiRaGe.zip - http://www.mediafire.com/?4ecqlu1t1usacyq
LS670_patch_CM7.2_IHO_07162012_MiRaG e.zip - http://www.mediafire.com/?anin0k1ynhohi3k
VM670_VZW_patch_CM7.2_IHO_07162012_ MiRaGe.zip - http://www.mediafire.com/?zwynuod3amtlja3
Hope it helps...
Sent from my MiRaGe OV using Tapatalk 2
Is there any way to fix the GPS bug in maps? My phone reboots if I attempt to turn on GPS while using maps. Are there any other GB ROMs that include such a fix? It works for stock 2.2, correct?
Thanks
Thanks
Works fine for me. Maybe a bad wipe or bad flash. Somehow something got corrupt.
Sent from my Transformer TF101
Mirage is your ROM just as secure kernel wise etc... as ICS and JB ROMs.? Thanks
Sent from my LG-VM670 using Xparent Pink Tapatalk 2
Love mirage and have used it for the bigger part of a year. Never had an issue like this before so its odd this shuld happen now.
Should of backed
Upbefore the update ...pretty much standard procedure ...;)
Central Forums
I've never had that problem with this ROM. Try a re-flash. Also, are you using Beats / anything similar?
I was hesitant about flashing beats audio but in very pleased and happy with the sound I'm using altec earbuds what are very nice and also affordable.
But yes DSP will have to be disabled frozen whatever I'm using audio FX equalizer widget As suggested
There are Beats that don't affect DSP manager. MegaBassBeats is one of them.
any reason the ls670 patch isnt working? I really love this rom but I cant use it with my ls670. I'd love to see it be fixed!
Aguswibowo
