[ROM+Kernel] MiRaGe-CM7.2-IHO (07132013)
Re: [ROM+Kernel] MiRaGe-CM7.2-IHO (04152013)
This is the best my phone has run in the last 2 years, this rom is so smooth and responsive but still not great battery life but better than it ever was.
I have had great battery life with this ROM.
CPU was 480min 600 max interactive, and Juice Defender Ultimate with Aggressive profile.
No gps, brightness all the ways down, and sync off
I could go a day and a half on a single charge.
Sent from my CM9 Optimus Elite!! :p
I turn everthing off, everything. I only use Periodic Auto Sync, which I have set to sync every 4 hours and only for a minute. Don't need Juice Defender. I turn things on when needed, and turn them off when not in use.
I can go over 6 hours on WiFi with screen on connected to the internet the whole time.
I do the same, everything turned off, screen at 22% ,only get my gmail when i feel like and when on charger. Great battery when on wifi but its rare for me to get wifi. Never tried juice defender or the like.
As soon as i turn on 3g i'm suckin the juice, but not near as bad as when i ran backside.
Hell, if i didn't need 3g i could probably go 2 to 3 days off charge, oh well watta ya goin to do.
What happened here...?
This occured yesterday outta the blue.
Nothing has been changed in any way.
I went as far as to re-install the widget and also did a re-flash of the kernal.
obviously a few reboots after all that...
Ideas?
Ideas?
You could try reflashing the ROM only wiping cache and dalvik. If that don't work a clean install should work.
The later versions of the kernel in this rom manage the gps automatically - just leave it on and it gets automatically turned off when it's not needed and turned back on again when it is. No more having to manually enable it when you run maps or navigation.
Thanks for sharing that info, i had no idea you could do that, that's cool!
Don't hold back, got anymore tips it would be greatly appreciated, this rom just keeps gettin better! ;)
Does ##virgin# work for anyone on this ROM?
Does anyone know?
Should i be running the 4-26-2013 kernel? I just seen it on the first page.
Does anyone know?
I believe it's already part of the lasted version of this ROM. The OP put that up for the prior version of the ROM.
Does anyone know?
I don't think so. The ROM was updated on 4-15 and the kernel is 4-26.
Sent from my LG-VM696 using Xparent Red Tapatalk 2
I went as far as to re-install the widget and also did a re-flash of the kernel.
Ideas?
Hey guys, I'm still having this problem with the FastCharge widget. I've done everything as far as reflashing the ROM, kernel(prev version and latest), re-installing the .apk multiple times. any other ideas?
Does the app/widget itself need an update?
*Note that after a re-install of the widget and applied onto one of the launcher screens it does work for a short period of time...then changes to what you see above.
Thanks for any input and other suggestions.
Yeah, I've been having a problem with the latest version of this ROM where a brightness widget I'm using refuses to change the brightness level after a while. I've turned off auto brightness, so it's not that. I have to reboot it to get my brightness adjustments to work again for a short time until it stops again...wonder if the problems are related?
This was discussed before in this thread and also linked to the that discussion in the third post.
http://forums.androidcentral.com/op...rage-cm7-2-iho-04152013-a-18.html#post1960209
On An additional side note not rom related... what's about mismatched MIN's?
Would a matching number help as far as a signal using / changing a PRL#?
I changed it cuz it was an unknown area code!
Phone was new in package when purchased .. & only upgraded from a flip phone and transferred #. Intrigued. Indeed
So After doing this I can see tha
t attempts times to be made to make calls outside my countyhave
ce gotten screwed ..
sshkjgh7788
