Re: You really need link2sd on this phone
Yes, often the best solution is to start fresh. Save anything you need, then wipe EVERYTHING - internal and external. Create new partitions and format them - I used ext4. And leave a nice big partition for link2sd to use - I split my 8 GB sdcard into half FAT and half EXT4. Install the rom. Install link2sd as one of the first applications. Again, check the beginning of this thread for recommended settings to have link2sd automatically move everything that can be moved to external storage. When you get everything working the way you like, do a full backup. MRG666 has produced the best performing, most functional ROM for this phone and for that, we thank him!
Link to Link2SD frequently asked questions.
Well, I installed MarketFix, started it, and clicked the button to have it do its magic. I then went to the Market and tried updating apps, but they failed just like before.
I watched my free space using "adb shell" while installing updates and indeed the cache partition gets to 100% utilized which triggers the "package file invalid" error. Not sure why MarketFix didn't work for me. (I even tried enabling it a second time, rebooting, etc.)
I also didn't have luck with Link2SD and having it try to relocate the cache partition to SD card. Maybe I need to completely wipe this phone and start over....something may be screwed up somewhere....
