[ROM][LINK][GB][2.11.605.3 ?][Sense3.5]BAMF SoaB v1.03
Re: [ROM][LINK][GB][2.11.605.3 ?][Sense3.5]BAMF SoaB v1.0
I flashed it and really liked it however I have a few issues with it. The my Verizon and NFL apps don't work again. Hopefully these will work in the next release. I really love the bamf roms!
I can't get the tasks widget to load, anyone have luck with this?
I have played around a little bit trying to get the widget to work with no luck, hopefully in future updates this and the NFL app will both be fixed.
My Verizon and NFL Mobile both WORK. You have to install verizonSSOEngine.apk and ssopermission.apk into system/app, then go to market install lte on/off, put the phone in cdma only, reboot and it should work. Worked for me.
Not sure if im allowed to post these apks. Mods delete them if needed!
just flashed this ROM, hope for the best....
I have it flashed but how in the hell do I turn off the sound after I unlock with the lock ring? Its annoying.
Settings > Sounds > Uncheck "Screen lock sounds"
Reactions: BigBoz
Battery life on this rom is much better than the 0.7 release.
About 1 hour on display and only in 4G area with moderate usage and I am getting upwards of more than 10 hours on the battery.
I'm noticing the same boost in the battery life compared to 0.7 release :)
I just flashed this ROM, did full wipe of everything as always but when I try to view my photos from my SD card, it says no photos or videos found. I never had this happen with other ROMS. Any ideas? Probably something foolish I'm missing?
For some reason I have the no photo issue and my fix is to un-mount the sdcard and then mount the sdcard in the setting without actually pulling the card out. I'm not sure why this happens on this rom and doesn't happen that often.
i downloaded the files and installed, downloaded the app. from the market for the lte on /off, tried to log on yesterday and today and it keeps telling me service not available. am i missing anything else?
I didn't install them, i just copied them into the system/app folder, than set permissions to rw-r--r--. Remember to reboot too.
I should have tried this but I actually, powered down, pulled battery, pulled SD card and put back together. Once booted up, still wasnt showing any photos but then second time I wet back into the gallary, eveything was there and fine.
To all my bros out there, I "de-pinked" this rom. Check it out!
SoaB De-Pinker!
Installed this... really love the Blue!!! And installed the two SSO apk files to fix MyVerizon, and then of course the NFL Mobile app works after I get logged into the MyVerizon app... and used this ROM for about the last 48 hours straight... I'm not see any issues with any of the apps I normally use... I think this is my new daily driver... until I find a new ROM to flash :cool:
Reactions: PapaSmurf6768
You went 48 hours without flashing :eek:
I'm also planning on using this as my daily rom since everything is stable and running smooth.
Well... almost 48 hours... after all I did just flash PapaSmurf6768's De-Pink Mod.... check it out... you can get your flash fix fairly cheap, just wipe cache and Dalvik cache, then a quick flash!!! :D
I AM having ALL KINDS of force closes of google something......google services framework (process com.google.process.gapps)
I don't see that app in the list of All apps... I'd first try to clear the cache on that app, check your list of apps under Settings > Applications > Manage applications > All tab... if you don't see it, then I might think about going into Recovery and do a Wipe Cache and also Wipe Dalvik cache.... if that doesn't fix it then I'd reload the ROM with a wipe of all data.
Dugoh1
