[ROM][LINK][GB][2.11.605.3 ?][Sense3.5]BAMF SoaB v1.03
I am noticing a lot of signal drops on this rom. I dont know if its my radio (2.5) or if its the rom. When I am streaming pandora the signal drops and I have no data at all until I toggle the widget and the data then comes back up 90% of the time. I am also familiar with the area that I drive in and it has signal throughout.
I might have to try a different radio or rom.
Hi. Im new to rom flashing. My phone is stock rooted, and updated to the last update before the Gingerbread update. Can i flash this rom? Do i have to flash the radios also if i do flash this rom? Ive read all the walkthroughs just couldnt find the answers to this.
Thanks.
I flashed this from the 605.3 ruu, and did not flash my radio file or anything else.
Thanks.
If you never updated you will need to download the Gingerbread radios. I flashed my radios after updating the ROM.
You can find the radio (LTE+CDMA) here: http://www.androidpolice.com/2011/0...d-rom-radio-and-full-ruu-for-htc-thunderbolt/
I am having issues getting data to stay connected as well. Did not have this problem with v1.0.1 but have had it with 1.0.2 and 1.0.3. Tried updating the radio and still having the same problem. Thinking about switching back to bamf forever cubed...anyone have any ideas?
got it fixed...
I flashed imo kernal 4.1.
So far no data drops, but my front camera is upside down. Not to big of a deal since I never use it, but annoying nonetheless.
I will let you know how data holds if I can withstand the upside down camera, otherwise I am going to flash to a different rom.
I flashed the imo 4.1 kernel. If that doesn't fix it then do the following:
1) dial ##778#
2) click edit mode
3) enter password 000000
4) click modem settings
5) click rev a
6) click enable
7) apply settings...phone will reboot
How do I change the bootanimation in this ROM? I replaced the .zip but I don't think it was the current one because it didn't work.
r3dpuk3
