[ROM][LINK][GB][2.11.605.3 ?][Sense3.5]BAMF SoaB v1.03
Re: [ROM][LINK][GB][2.11.605.3 ?][Sense3.5]BAMF SoaB v1.01
Update to version 1.01... changelog posted in OP Post #1.
Reactions: mclarryjr
Glad to have the task widget :) now I can try being productive again
Running this for a day now and it is surprisingly good. As smooth as anything else and so far not a real problem.
Only 2 nit pick things. 1, when using the new quick launch widget and setting Gmail to one of the quick lauch slots, new messages do not appear in the opening tab like a calendar event will or text message. And 2, the arrows have been removed from the bottom of the keyboard. I really liked those.
This IS my daily driver now unless something bad happens with it. All my apps work. And the improved camera is really cool
I don't know if its my radio (using the newest 3 radio) but my data was dropping a lot yesterday while streaming Pandora and driving. I would have to toggle the network on and off to catch a signal, which it did instantly.
anyone else experiencing data drops on 4G?
I'm not having any issues, but I don't stream music with Pandora. Since there are soooooo many radio's to choose from... are you talking about 2.11.605.3 radio files, because those are the radio files I'm using... and did you flash both the CDMA and LTE radio files???
base band is 1.48.00.0906w_1
0.01.78.0906w_2
0.01.78.0906w_2
That is the 2.11.605.3 radio files... personally I don't have a problem with these radio files... however, I have heard other complain about this version and they have had better luck with 2.11.605.0, but there is no reason you could not try flashing any other Gingerbread radio's and see if they work any better for you.
I am going back to 2.5.
I didn't have any issues with those radios.
Will let you know if I have anymore problems with this rom and 2.5 radio.
Is anyone having a problem with the People widget. When I touch any contact on this widget, I get the HTC screen like it is going to reboot but the phone does not complete a total reboot. Anybody?
A couple of the widgets force sense to crash and reload sense, your phone it looks like your phone is gonna reboot. I changed roms until things get fixed. I had the same issue using the stock htc weather widget.
What Rom did you switch to? I love sense. I haven't tried anything else but I'm willing to try. I just don't know which is more stable.
Is it ok to flash the 2.1 answer screen to this, I have been getting the "end call" bug?
Re: [ROM][LINK][GB][2.11.605.3 ?][Sense3.5]BAMF SoaB v1.02
do we actually have to wipe data if we are going from 1.0.1 to 1.2?
Shouldn't have to wipe coming from 1.01, I flashed the patch yesterday and everything is working brilliantly. Great work!
updated to v1.0.2. have been having issues with 3g data (very intermittent). I do not have 3G when I set to CDMA only. Running MR2. Should I update my radio?
It might be a carry over from yesterdays data problems... might... but if you are still running the old MR2 there are a lot of newer radio files... check the "Latest Radio's" link in my signature if you want to update.
Reactions: slimc84
is there one that seems more reliable than others? thanks for the help.
is there a way to add the the gingerbread lock animation? where the screen goes black into white line, like turning off a tv? this is my first time rooting, so i dont know whats possible and whats not...
r3dpuk3
