[ROM]MIUI GingerBread Release5 4.26.2012 ZVD
Re: [ROM]MIUI 2.3.7 Release4 4.14.2012 ZVD
You can run ES in root mode from settings
So I finally got it to work! Everything's great! Thanks!
First, thank you for your time on this ROM!:D
Just flashed this from Reborn and took 2 attempts and then booted perfectly...
Finished restoring my apps and everything is working great (camera, MMS, etc...)
Another big thanks!!!
Question, I read on an earlier post that "wireless tether with root" worked with this ROM.
Where can I find this apk? Checked Play store and couldnt find it...
My wireless tether widgets are not working like as in reborn, etc...
Any help much appreciated. Now going to install some themes and NOT select lock sreen ;)
clicky
Reactions: CubanoRafter
A kind of side note: If you use Titanium Backup, you can always back up your wireless tether and re-install it if you move around to different roms. That goes for any app you may want to install in the future, tbh.
So the themes seem to be working fine and I'm using MiLocker which comes from MIUI and it has the same database as the theme app in MIUI so i can find matching lockscreen themes. Some screenshots. thanks for the great work!
attachment.php
attachment.php
attachment.php
attachment.php
Reactions: rukin5197
It appears that this is getting plenty of attention and most things are resolved, so I added this to the Welcome Guide.
Thanks for all your hard work in porting MIUI!
Reactions: Invincible Madness
Another question LOL
SMS doesn't get themed yet right? My SMS always look the same no matter what theme I'm using.
I applied the suave dark theme and my SMS is themed
Sent from my Amazon Kindle Fire using Tapatalk
Thanks for the info. Did you download it through the theme app or did you download the theme elsewhere and put it in the theme folder?
Downloaded it from elsewhere. But I have had it work both ways
Click the theme and check if it themes SMS. Not all the themes do. I applied black android theme and it did theme sms.
Checked SMS already. Not sure why it wouldn't work. The clock wasn't themed at first but then it fixed itself somehow. I'll try other themes and see.
Vamshi, we can FINALLY have a number!
MIUI-2.4.9: s5830
I'm porting it as soon as possible.
What did your sms look like before you applied any theme? Did it look like the image in the default theme preview or did it look like stock CM7 sms app? Mine looks just like the CM7 sms app with black background.
Here are 2 for example
Thanks for the screenshot! I don't know why it's just me... My statusbar doesn't theme completely either. I have to uncheck "status bar" or the left end would be black while the rest is transparent...
pamatika
