[ROM]One small step for man one giant leap for --- Liberty 1.5 2/2/2011
Anyone have any idea why I can't use any of the Liberty Settings. I click on Menu from the home screen, then select settings, then liberty settings and it force closes every time. Any ideas?
Happened with me the first time I installed Liberty 1.0.
Went back and wiped date/cache again. Reinstalled the ROM. Worked fine after that.
Reactions: dbdynsty25
I tried downloading the actual Tom zip via my phone and it wont work .... keeps tellling me unsuccessful first time it does that to me Idk why
Sent from my DROIDX using Tapatalk
Don't mind victor he'$ probably drinking again.
just a quick note
after flashing this rom (what i assumed to be correctly, back up, wipe data & cache) my phone resets itself after every call no matter how short or long and even on missed calls...any ideas on why this is happening and possibly how to fix it?
just a quick note
If you flashed a theme other than whats in the toolbox this could be the cause.
i did flash the no clock mod by fab, my buddy at work did it and originally i thought that it would crash the phone since its not the same dev. (at least i don't think so) but his was fine so i thought it would be ok on mine. he's also running liberty 1.5
Revolution Remix is SICK!!!!
He's getting by, but he won't get away. Reflash a backup and consider this a lesson learned. :-)
Reactions: rob_ashsu
Where have I been....my oh my...
A lot of nice changes. One problem, I'm using Quick Clock and Set CPU, and it won't really overclock. Just slightly above 1000, before it was running well at 1200. I've tried the calibrate function a few times.
See it wont let me
How are you trying to DL to your phone or to computer?
Which link are you trying to DL from ?
I got mine from "Bgil55"'s link.(118mb)
Did you check the size of the dDL to make sure it downloaded all? (118mb)
I always download to computer and then drag to root of sd card seems to work best for me(personal preference)........ also your not drinking again are you,ha :p
richardgroover
