[ROM][PORT] Icy Viper MIUI
I believe your phone has a hidden fastboot mode somewhere.
Someone try adb reboot bootloader or adb reboot fastboot. Something that'll get you into fastboot.
I GOT IT!!!! Ok I am on ZVD Flashed AlphaC then ICS then Alpha C I haven't seen MIUI yet but I have CWM on ICS!
Now I factory reset and it is back to the Enter the fastboot.
- - - Updated - - -
Should I wipe System, Data, and Cache then mount them all and install what I've done?
Re: MIUI Rom
Try ZVD. I think it's just a problem with ZVC. I wish i could be more help, but i have like 20+ pages i need to fill out for this internship.
Where you doing an internship bro?
Sent from my SPH-D710 using Tapatalk 2
- - - Updated - - -
You are right, i may be onto it...
Re: MIUI Rom
Ok update, it installs and stays, you get LG Security Error every boot. So is there anything we took out? I can put all the apps back in if you want.
Ok well that's a start maybe ill go thru the system apps and see what missing
Sent from my LG-LS840 using Android Central Forums
Security Error? I thought that was only stock. Hmm..
Yeah...are you sure you ran a full image flash? sounds like you had prior google apps removed and ran a built in factory reset...
Don't do it yet the updater script will format system and still give u an error. Its because alpha1c is the stock ics boot.img
So my question is does anyone know where the security error is stored I know the image is in the boot.img
Oh and progrande check your pm
I can unpack your kernel and search for it if you want me to
Yes pls. Just wondering if we could disable the check at boot. also what tool do u use to unpack the zImage.
Annuji202
