[ROM][PORT] Icy Viper MIUI
Found it. It's in the /res folder of the boot.img
Yup but if you delete it it will probably just boot to a blank screen...and I searched inside all the files in boot.img for an errorlogo.png reference.
Sent from my LG-LS840 using Android Central Forums
What you use to unpack it?
Edit: What platform are you on, Windows, Linux, Mac? You need Mac or Linux to do this since everything Android requires case-sensitive filesystems which NTFS (Windows) doesn't provide.
Guys, it is simple just download ZVI then install it, then install AlphaC, then flash a 4.0.4 GAPPS package.
Seriously then it boots into project panda?? Oh I wish I was home to work on it.
I must have misunderstood your posting when you said the ROM booted.
Sent from my LG? Viper? using "the force"
Yeah, I put that it won't boot it is an auto fastboot I'm not able to do this ATM but I need someone to do the whole thing, yes it is a brick but if you can get it right it will work. Ok. Install ZVI then Install the AlphaC from apha1c.zip. Now find a GApps package to use in it, flash that. Make sure the Gapps are for 4.0.4.
If nobody tries it out by this afternoon I'll give it a shot.
What distro of Linux is this?
Ubuntu 10.04.4. If your trying to build android, it's recommended that you use 10.04.4 since building inn the new versions of Ubuntu is unstable.
Sent from my SPH-D710 using Tapatalk 2
So is anyone working out the bugs in this?
I've been setting up Linux and have gotton used to it, developed on roms for the Galaxy Nexus, Status 6 is an error that's slightly easy to fix, so let's get to it shall we? I'll edit the post when it's done :)
cinemacritic
