[ROM][PORT] Icy Viper MIUI
It's actually already been fixed on the build pinned there, could someone test that and tell me the error you get?
Re: MIUI Rom
Still working on this, I've in one day, created 4 different zips of it. I'll be uploading them to mediafire here ---> My Files!
Re: MIUI Rom
Well, for one, you mislabeled the first command in the updater_script
You have it as:
up_print("This is a super beta, it's doesn't boot. Do not try this xD.")
It should be:
ui_print("This is a super beta and its doesnt boot")
Remove the apostrophes, commas, and periods and try flashing again.
Re: MIUI Rom
You have it as:
It should be:
Mistake #2, if you flash this ROM to your phone, you are REQUIRED to wipe system, otherwise you get a bootloop.
Re: MIUI Rom
#3. Your ROM is missing a recovery. Custom ROMs contain recovery images so users can restore their system in emergency situations. Make use of this. There's recoveries on this forum.
Re: MIUI Rom
I decided to just stop. Someone please grab me the ZVD boot image, as well as a pull of the ZVD /system partition. If possible, a NANDROID will suffice.
I'll just restore my device with the nandroid (softbricking it) and grabbing the necessary stuff over ADB. I believe backup works in TWRP.
cinemacritic
