[ROM][PORT] Joyfully Optimus - Ios Gingerbread Rom!!!
Music apk on ics
Is there anything special you did to get it to work on ics? or did it just work right off the bat? :D
Said it once, and.ill say it again.
JoyOS apks aren't special. You can use them on other roms. MMS.APK JOYLAUNCHER.APK MUSIC.APK and all the other themed iPhone apps. Idk about settings.
Reactions: torch2424
Thanks you :D I misread your post and thought the exact opposite :0 sorry for making you repeat yourself
I would flash to find out, but I'm on the road. Does this have acore force close?
Found one problem. I logged into my school email. It says it 'needs security settings...' in the status bar. I go to click it and get this error: 'Sorry! The application Settings (process com.android.settings) has stopped unexpectedly. Please try again.' Tried clearing data, and rebooted a couple times. Didn't work. Anything I can do to fix that?
:thumbup:Confirm MMS is fully working, really smooth, overall really Good ill post some pic later, thank you! Great job:D
Have you tried wiping you Davlik Cache? :0
Wait that's using apktool though.... You said something about smali?
He said to use to use apktool to decompile a .jar file. wait scratch that you need to extract the classes.dex file from the framework.jar, then use baksmali to decompile that dex file to get to that directory. sorry for the confusion XD
Downloading now:) will test tomorrow since its 4am where Ian at lol
OP updated, please tell me how it works for you guys! working great for me in the past couple of hours :D
3G works right off the bat. Notification bar now says "Virgin Mobile". Nice work!
Machetaseo
