[ROM] [PORT] Modded JOYOS for Optimus V- HUGE UPDATE 11-11-12
I loaded up this rom. It feels just like an iPhone lol. Its also got ridiculous battery life with stock settings, and somehow barely uses any system ram. Don't know how you did it, but this roms definitely added to my awesome roms list.
I'm shopping for that last ROM my OV will ever load... I got a new phone on Black Friday and am going to turn my OV into a music player for my 12 y.o. I had been planning on doing Harmonia (simple and worry-free), but the idea of turning my phone into something that looks like an iTouch sounds like fun, too. So, for those who are running this -- Is this simple/stable enough even a kid can use it? Or, should I stick with tried and true? (Phone will not be activated. Main use cases will be tunein radio, music player, and camera.)
Would be good for that
Its very stable
I will be doing the same for my son
As soon as my shiny evo shows up:D
I'm curious, Will this work on the optimus slider. im half tempted to give it a shot.... it depends on the responses i get.
You have to port it over to your phone.
Since the slider is on the same network you will only need to swap a few files. You shouldn't have to edit the framework.jar.
For a better understanding go here: [GUIDE] How I Port
You should be able to port all ROMs made for the V over to the slider. You just have to figure out what files to pull from the framework of the slider and move over to the framework of the V ROM your porting to get the physical keyboard to work.
If you need help with the porting, or setting up APK MultiTool on your computer (if you do end up needing to edit the framework.jar or .apk), just PM me.
The biggest determining factor is the screen size. MDPI to MDPI = Success.
MDPI to LDPI = Failure.
The screens have to be the same size.
Very happy with this ROM, Thanks again for your hard work!
2 sweet surprise:
1) WIFI tether works, and smooth
2) download and install apps has an option to install directly on SD, save one step to move to SD after installation;
GPS works instantly
wifi catch on on 1st try
play store works
Installations: dl from OP, wipe everything, and install ROM/gapps and enjoy.
have NOT find anything that is not working... try very hard, still cannot find anything that does NOT work. Thanks again for a knockout ROM,
bun
bun
How did you manage to download directly to SD card if I may ask? I haven't found that option.
Thanks for the updates! Been waiting a long time for someone to pick this up!
It took really long to download the ROM (45 mins.).
when click on app download from playstore, a menu comes up asked permission to download to storage, SD. Not quite sure where to do the setting. It just comes on by self. Sorry, not much of a help.
bun
Tfunz
