ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Nick7 & RebornROM Family...
Kind of a stupid question...forgive me:
I'm running Reborn v.2.2.4. It's been ages since I rebooted into recovery to clear the cache. So after seeing some 'weird' behavior...I decided to reboot into Xionia...and wipe both cache and dalvik cache (as I have done many, many times in the past).
Now when I reboot, it gets stuck on the 'LG' logo, before the boot-animation.
Before I proceed to restore my latest nandroid...should I just wait for it to boot correctly? Should I have not done a cache and dalvik-cache wipe?
I have also implemented the 'Data2EXT' SD Partition tweak.
Let me know if you have any ideas.
Thanks,
BJ
!@$%!#$%#$ oops, I did that when I was initially figuring out the data2ext sd partition tweak. I always meant to go back and figure out what actually caused the problems and if there are certain steps to correctly wipe the cache and dalvik-cache after the data2ext tweak. If I remember correctly I was able to boot again by doing a "dirty flash" (flash RebornRom without wiping). You will need to run data2ext again if you still want that mod.
Reactions: biggjoe
Thanks,
BJ
The *SAME* exact thing happened to me last week. 1 hour before a 3 day, 600 mile road trip.
Still haven't rebuilt the phone completely yet (life gives me no time).
Running Reborn and data2ext.
All input welcome.
Ok, the phone actually ended up booting back up after 3-4 battery pulls. However, the Data2EXT was gone...my available internal storage was like 40mbs.
Before restoring Nandroid...I'm going to simply redo the Data2EXT tweak...followed by moving the Cache back to where it needs to be (remember all the issues with Android Market Application Updates) and see if that brings the phone back to normal.
If not, I will restore Nandroid, then redo the Data2EXT tweak, then fix the cache.
BJ.
afaik its not being developed further. Its been stable for a long time, developers have moved on to GB. This ROM is perfectly fine to use. I just recommended it to a friend two days ago.
*** Nick7,
Are you developing a GB version of RebornROM? If not, are you partnering with anyone to develop a totally NEW GB-based ROM?
RebornROM Rocks!!
BJ
*** Nick7,
RebornROM Rocks!!
BJ
Check out the just released "YOUR-MOM ROM". Should be pretty much what you're looking for :)
Nick is part of Team Hydro. This ROM is not being ported over to ZVH and in turn we have a new ROM out. When Nick gets time im sure he will let you all know what the plans are. :cool:
*** Jondevere,
The new ROM that is out (the one you referenced)...
1. - Is it specifically for the LG Optimus S?
2. - Is it already fully released?
3. - What is the name of the ROM?
4. - Can we begin installing?
Thanks!!
BJ
*** Jondevere,
Thanks!!
BJ
Check the forum ;) Its hard to miss YOUR-MOM :cool:
BJ.
BJ, did you figure out why you weren't able to boot after a cache and dalvik wipe? The same thing has been happening to me. For the past month or so my phone gets stuck on the LG screen after a cache, dalvik, and debug wipe. I do not have the Data2EXT tweak. I'm running almost stock Reborn, only change is the button wake tweak. I usually just restore a Nandroid.
Any insights or help would be greatly appreciated. Thank you.
Vinnie
Sent from my Reborn Optimus S using Tapatalk.
Ugh. I just came to ask for one more update with only the Google apps updated. I can't get the latest installed and I've been reflashing Reborn about once a week to try to clear some download cache so I can update pretty much any app. It's the phone, but this ROM makes it useable!
Sadly I see that Reborn is RealDead now ... :'( Bummer.
ROM is dead. As Jon said I will be helping out with future development for the Optimus and any other devices Team Hydro takes on.
You are more than welcome to use Reborn ROM but I highly suggest checking out Your-Mom! I know I am.
thanks for the heads up, RIP Reborn ROM...it was a fun ride!! great job on it, looking forward to whats to come for the optimus
I downloaded it and placed it on my sd root and followed the steps but when i go to flash the zip it says some stuff then says aborted.. any know why?
Did you modify the zip at all? You could have a corrupted zip as well, try re-downloading the ROM.
Status
mama baer
