ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
diggin the name change and update...nice/simple boot anim. caught myself looking at it a bit to much, got dizzy jk.
dig the look of the notification bar/drop..(icons etc).
thnx for all the hard work.
runnin' smooth.
Having trouble connecting to wifi with static ip now. Didn't have this issue with nameless. Anyone else experience this? Tried a couple different times now just so you guys know I'm not trying to pick the ROM apart. My home network is static ip with wpa2... So that's my only option to go wifi lol. I am enjoying this ROM other than that issue. Then again, I've been working all night so it may just be fatigue setting in for me... Any guidance, others' experiences?
EDIT: More information for devs (or others testing): After setting static ip in wifi settings, phone attempts to connect. Quickly sends security code and then displays "Obtaining IP address from ****..." Then after trying for about 30 seconds the phone goes back to scanning for local networks. Also, wireless router is definitely working because I'm using it from my computer right now. I've tried to cover every angle of this before reporting... No themes loaded either. Just Reborn ROM with noIQagent.zip flashed
EDIT 2: Seems the issue is the phone is not setting itself to static ip. I switched the router to use DHCP settings and left the phone set to use static ip and the phone accepted the DHCP ip address (which is not normal). The phone should have set the ip or overrode the router. I have the phone set to use *.*.*.104 and the router assigned *.*.*.102. I believe the phone isn't sticking the static settings in the advanced menu... Just my results and thoughts from the quick tests I've done.
Have u tried unplugging ur router for a few mins then plug bk in (during this turn of wifi on the phone) then plug router bk in give it abt 5mins then turn on wifi on phone shld b good to go..
That's not the issue... Thanks for the response though :)
Great update - Seems even snappier than before and still as smooth as butter! Thanks so much for the great work.
Love the update, but I must say I am not really thrilled with the new name.
It probably wasn't the developer's intentions but the name has a religious or spiritual connotation, which while not in any way improper, does not suit me. (Read: I know as soon as my fiancee sees the name in the notification area she is going to give me **** - hope that doesn't offend anyone). O:-)
zombies are reborn too. i see nothing religious in the name.
I haven't flashed RebornROM yet (so I have no idea where the name gets referenced onscreen). But, am I the only one who thinks that someone might be a bit fanatical if they make a correlation between some custom Android OS and religion? I'd be more worried about the people that get offended by such nonsense.
Reactions: antipunk
just wiped the caches and flashed over, works great. notification bar rocks. thanks for the update!
"Those people" will be cheating themselves out of a great life-experience by not using this ROM due to the name. ;)
Error when installing noIQagent.zip.
I am updating over original version. Ran process twice and getting an error when flashing noIQagent.zip from the SD card
" E:Can't open /sdcard/noIQagent.zip (unknown error: 0) Installation aborted"
did you fully boot into the rom first the reboot back into recovery?
also NO wiping between booting fully into the rom and flashing the noIQangent.zip
Status
Nazeer zaheen
