ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Error when installing noIQagent.zip.
I am updating over original version. Ran process twice and getting an error when flashing noIQagent.zip from the SD card
" E:Can't open /sdcard/noIQagent.zip (unknown error: 0) Installation aborted"
Try reflashing the ROM first.
And you should be flashing it from the recovery menu on your phone. I hope you're not using the computer...
EDIT: Clarify "Original version". Stock firmware?
flashing from phone not PC - I have not linked to PC at all...downloaded Reborn from phone...
flashed Reborn over the original NamelessROM. I did clear cache first..but did not do a complete wipe. Should I have?
Wipe data, cache, dalvik all from recovery. If you like to save your app data use titanium backup and select individual apps to backup app+data. i.e. I backup dolphin browser with all my bookmarks then just download titanium on the new ROM and restore each INDIVIDUAL APP. Don't do a full restore!
Edit: Some have had success without clearing data, cache, and dalvik but I suggest doing it any time. It gives the ROM a fresh interface to work from... Can't hurt either (other than having to log back into gmail....)
thanks for the new rom can't wait to try it. what is the "no calleriq patch zip" or was that there from before lol
patch is old. you are looking for noIQagent.zip on the root of the sdcard. You may need to use file explorer and move it to an accessible folder...
Got it. Thanks. I had to wipe the data...didn't work the first times when I didn't.
Now just need to get all my app data back from titanium.
Thanks Again!
OK, just flashed Reborn from nameless. NASCAR app worked flawlessly in nameless and now says that it is only available to Sprint/Nextel customers in Reborn. What's changed?
We need to adjust the Sprint apps.zip to compensate for the name change
Ah. Will wait for the updated zip. Thanks! You guys have made a awesome ROM even better! Love the new notification bar widgets. Can't wait to see what the battery life is like now.
Is there any way to get all my apps and catagories back where they were in the app drawer. I am dreading setting that up again
All of the ones that you backup will appear under the downloaded section. The "cleanest" way to do it is to just restore them and place them back in the drawer that you want and setup the drawers from scratch again...
Yeah...thats what I was afraid of :)
The Genie widget looks great, I always had to overwrite it with my custom transparent background but not this time :)
Status
Arwen
