ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
I knew this would happen. I went from Thunderom and installed Reborn V1 last night, and thought about waiting until V2 came out. and low and behold V2 comes out 12 hours later .....
Well updating to V2 now.
Thanks for the update and rom, keep up the good work :)
Still having static ip issue. If you don't experience it, set your wireless router to "dhcp off" and try to connect by setting a static ip on the phone.
Error when installing noIQagent.zip.
I am updating over original version. Ran process twice and getting an error when flashing noIQagent.zip from the SD card
" E:Can't open /sdcard/noIQagent.zip (unknown error: 0) Installation aborted"
I am having the same problem. Yes, I am following all of the instructions, except factory reset. I think Nick said that was not required when simply updating from V1. And yes, I am using the correct file, the one that is created at root of SD Card.
I did have a theme installed before, with the noiqagent built into it. Am I correct in thinking that perhaps the theme and previous noiqagent survived the cache/dalvik/flash update?
Thanks
G
Thanks
G
If you see my response to the post that you quoted, you will have your answer. You were almost there. It's only a few more down... Going to sleep. GL
Thanks
G
I had to do the complete wipe before I got it to work. But it seems others didn't.
Sorry, should have clarified. I did flash the ROM first, fully booted, then booted into recovery and tried to flash the newly created zip. Gave me the error. I may just have to do a full wipe; I would just rather not. Can I retain connections to both Amazon Appstore and the Android Market if I backup and restore apps?
You would have to use Titanium Backup to backup the market links for Android Market, not sure about Amazon though.
Reactions: generosity
I flashed V2 last night. It's awesome! I love the toggles on the pull-down menu. (the orange one is for GPS, right?)
If you guys really want a different background, drop a white or black png in framework-res/res/drawable-mdpi and name it stat_power_background.9.png
Reactions: mike9670
I don't have the know-how to make a background but if someone can make one and post it here that would be awesome.
After installing the Nameless ROM everything appeared to be working correctly. But when I tried to restore my apps with Titanium Backup the phone froze. I had to pull the battery to restart the phone. When I tried to access Titanium again it told me there was an ?error while launching activity?. Then I went to the SD tab in Manage Applications it has apps listed with their complete file name (as opposed to the app name) and there is a gray SD card symbol instead of the icon for each app on the SD. But photos and music are fine. I tried running ?Fix apk uid mismatches? from recovery but it didn?t fix the problem.
I thought I?d try to reload Titanium from the Market but when I click on the install button in the Market it takes me to the accept permissions page but when I click ok nothing happens. When I go back the install button goes gray and I can't click it anymore. I tried to clear the Market?s cache but when I go to Manage Applications it NEVER stops COMPUTING and I can't do anything but Force stop and Clear data (which I did to the Market and it didn't help).
I wiped data/factor, cache and dalvik then restored a nandriod backup I had from before the problems started and I have the same problem with all the apps on the SD card.
Next I wiped data/factor, cache and dalvik again and did a fresh install of the Nameless ROM zip. Only difference with this method was I don?t have any apps listed on the SD but I still can?t load anything from the market nor can I access Titanium to load any of my apps.
Does anybody know what I can do to get the phone working again? Any help with this problem would be greatly appreciated.
The current image at that location has the button shadows. I can create a solid black png of the same size, but it probably wouldn't look as good as someone who is good with photoshop and can replicate the shadows in a darker color.
Love the update, but I must say I am not really thrilled with the new name.
It probably wasn't the developer's intentions but the name has a religious or spiritual connotation, which while not in any way improper, does not suit me. (Read: I know as soon as my fiancee sees the name in the notification area she is going to give me **** - hope that doesn't offend anyone). O:-)
Wow.. dude.. u have more issues that just a rom if your wife is gonna give you **** for the name of the rom dude... good luck with that one.. THE NAME IS AWESOME BTW
Ok so im havung a little trouble wen I install the noiqagent.zip an reboot it just bootloops at the reborn loggo can any one help
Status
cashinminutes
