ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Alright so I have been doing some tweaking for better battery life. My latest build goes as follows:
1. charged to 100% while powered off.
2. fresh flash, battery stats wiped.
3. phone has been on for 24 hours and is at 7%
usage was pretty heavy and includes: 3-4 hours of web browsing, 1 hour of talk time, lots of text messaging, 4 hours of music playing, 1 hour of pandora streaming, 1 hour of wifi usage.
How does this compare with your current setups? Would this be worth releasing?
You squeezed about 6 more hours than I've been able to get, I did not wipe my battery stats recently though. Similar usage however.
EDIT: Second thought, I have been on wireless pretty much constantly lol.
EDIT 2: Almost forgot, yes, release
was this without juice defender and ultimate juice? if so its pretty damn good!
could you also add hotspot toggle in the notification bar!!!
It's built into the framework already, but if you enable it you can't turn it off with the toggle due to LGs framework. That's why the wifi tether application is there. Sorry fellas.
2.1 woo
downloading 2.1 now, but I am a little curious.
If you've removed the noIQ patch is there another way we can go about disabling the IQ agent, not entirely rom related sorry.
EDIT: Just for curiosity sake would flashing one of the other IQ patches from nameless or reborn v2 work?
EDIT 2: Flashed as update only wiping cache and delvik cache, works great. Will likely report back in regards to battery. Thanks again Nick
I think the reason people had problems was due to flashing the nameless IQpatch instead of the Reborn v2 patch (that gets auto-placed on the micro sd card).
I have noticed that rom has issues with live wallpaper. I thought it was becouse I was pulling from the sd card but it happened again when I was doing live wallpaper from internal.
Crashes phone and needs battery taken out and reboot.
Another issue I have seen is with loading different keyboard such as gingerbread keyboard it wants to change back to htc keyboard at differnent times, sometimes when rebooting and sometimes at random.
Did you do a complete wipe before flashing?
I'm about to flash, so I'll check it out.
yes.
This was the first time testing live wallpapers though.
Tried different wallpapers and only the live ones have issues , sometimes not at first but after a few minutes to 10 minutes of use.
I just tried two live wallpapers, both were working fine.
For those of you who really want the noIQpatch, yes the one from Reborn v2 works. It isn't that big of a deal though.
Reactions: sblood86
Is it possible to flash the changed files on the ROM so I don't have to reflash the whole thing?
If so, what do I have to flash/push?
Also Nick, can you let me know what setting changed so I can Google it? :p
Thanks.
OMG!
Thanks to all fo you that hand any part in this rom. I installed just like you said and yes, it went gerat and yes, this is my fav thus far... keep up the good work!
Status
Crghjuygf
