ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
It will not work on that ROM, I had the same problem. I had to use CM7. BASH is not in the system as it is with CM7 and I couldn't figure out how to insatll it.
Well if I have to switch roms I know it works with shell rom i've had it running on it but just prefer reborn over it so i was hoping i could get it working with this one.
So I installed this rom and I love it my only concern is my internet keeps droping and I have to disconnect and recollect my WiFi to make it work again any suggestion :-)
I've been running it for about a week now (Versions 2.0 and 2.1) and I've never experienced that issue, have to tried to reflash it?
I'm having the same problem but I have to restart my phone or pull the battery to get it to reconnect via all it does is scan an re scans like a boot loop
For some reason after I rebooted my phone, I come back and see that my widgets aren't loading. Okay no big deal, but when I try to put them back they aren't there for selection? Any one know what's wrong?
Also, I might have made a mistake, does updating the PRL do anything to the phone/root?
So I found another funny problem I went to install some apps from the market and it won't let me download the apps it trys then just stops it won't even let me do update tried with WiFi and 3g and have done cold boot and warm boot of phone
Check your cache size by typing "busybox df" (without the "") in the terminal emulator program included with the ROM. It sounds like you don't have enough space left to download and install updates from the market.
You are supposed to update your prl and profile every once in awhile, so no worries, it should help with reception issues if they made any changes in your area.
- Sent from my Optimus S
Loving this ROM. Thanks to the devs. Went through ThundeROM, Nameless, Reborn 2, and Reborn 2.1. Battery life has kinda tanked with 2.1, which seems to be the opposite of the dev's intent with that release. Didn't wipe data this time, just an upgrade. I'll give it another day or so before a clean flash. Maybe back to 2 if I'm still having issues.
I personally don't have any battery issues at all. I didn't with Nameless, Reborn v2, or Reborn 2.1; though when I installed (full wipe) Reborn 2.1 I reset my battery stats. I have my brightness set to about 50%, and don't have too many background services consuming the battery. I can usually stream music through Pandora for about an hour and my battery will only drop ~3-5% on average, which is pretty good in comparison to doing that with Stock.
Tweak your settings, see what works best, what doesn't.
I'd suggest either a clean wipe, or a battery stats wipe (which I did), and initial impressions are that battery life is much better so far.
So I checked it and you were right my cache was 98% used now my phone still has 100 mbs of free space is there a way to rise the cache size so I have more space. I have got it down to 92%
You can wipe cache from recovery, or use an app like Root Explorer to delete downloaded .apk files that may be in your cache partition.
Im having issues with yahoo mail app not notifying me when i receive new emails. Is anyone else having this issue?
Did you move the widgets to your SD card? They need to be on your phone's internal memory, not the SD card...
This Rom is awesome except I am having a problem with one program. It runs fine on Thumderom and CM7. The program is echolink. The audio is slow and choppy on this rom. Any ideas on how to fix this?
Status
reijee
