ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
I've got a question for you guys. I enjoy using GoSMS Pro as my SMS app and I was wondering if there is a way to change the default SMS app that is launched when pressing the messageing icon on the bar at the bottom of the Reborn launcher. I could not immediatly find a way to configure the launcher when I looked. If it can't be done it's no big deal. I can live with the default app.
Mounting Second SD partition for Link2SD
I previously used Xionia recovery to create a second partition on my sdcard. The partition is ext3. Previously while running Lego ROM, I was able to run Link2SD which mounts it at boot time as /data/sdext2 and moves selected app, app cache and lib files to it. After switching to Reborn ROM v2, Link2SD can no longer mount the partition nor can I mount it manually in Terminal Emulator or using adb shell. I know Picastick's v7 kernel has support for ext2, ext3, and ext4, so this is basically a question for Nick7 if he knows of what difference between Lego and Reborn that might be the cause?
Further details: Link2SD mounts the script at boot with the same script in two places: /system/etc/install-recovery.sh and /system/etc/init.d/11link2sd. It was probably the init.d version that executed under Lego. The script contains the following:
#!/system/bin/sh
#added by link2sd
sleep 2
mount -t ext3 /dev/block/vold/179:2 /data/sdext2
mount -t ext3 /dev/block/mmcblk0p2 /data/sdext2
Okay, I solved my problem with mounting the second partition on Reborn ROM on the Optimus S. The kernel, Picasticks v7 does not have ext2, 3, 4.ko in /system/lib/modules. In my case it was said to have support but didn't. There are three things you can do to solve: 1) get a kernel that does have support. I used Zefie's v13 experimental which was the one I used under Lego ROM and immediately solved the problem. 2) Find and load ext modules yourself. Here is a link that discusses this in more detail The Ultimate Apps2sd Thread! - Page 2 - Droid Forum - Verizon Droid & the Motorola Droid Forum 3) Switch your partition to FAT32 which every kernel can handle by default.
Reactions: WetWilly#AC
You can replace any of the dock apps. Simply drag the new app shortcut over the old one.
Note: you must drag it from the App tray, not from one of your home screens.
yup, dragged Google Voice Icon over top the MMS icon and voila, Google Voice on the dock. :-$
make sure on your wireless adapter (plugged into computer) is connected to correct network. Also check your firewall settings.
I just tried the wireless tether and it worked fine for me
thanks for the reply. i rebooted my phone and it seems to work fine now. :D
Ok so so far I'm liking this Rom I do miss cm7 but it has to many bugs still but I would like to know if there is a way to replace the power control widget to a diffevent one i don't like that one that much I can't change anything on cus I don't use some if this widgets an I really like the one that come on the cm7 one so if anyone cane help that would be awesome thanks
Great work. Liking that Reborn theme. You should include it with the next release. Any chance of getting the stock sms with black background or has that already been covered??
Dude, please try to use some punctuation....I run out of breath just trying to read your question.
Anyway, there are answers buried in this very thread for you:
How to change widgets
Change background color
Change background color and add a circle battery mod
I am having a issue flashing the noIQagent.zip after flashing and rebooting when i get to Reborn boot logo. The dot spins around a couple times then stops i can feel the phone doing a vibrating pulse every couple seconds but it never gets pass this part. ive reflashed the rom rebooted and tried again with the same problem. Is anybody else having this problem?
I bet you are trying to flash noIQagent_patch.zip. make sure it is the one that does not say patch.
Sent by Tapatalk ----- Optimus s
Seems to me 2.1 removed the patch because people were getting confused about the old vs new... (now I need to figure out which one to use for 2.1... since I just flashed that over 2.0...)
noIQagent.zip is the one you want.
where can I find the one that doesnt have patch attached to it. ive tried finding it cant seem to locate it on here. maybe a link.
It was placed on the sd card automatically when reborn v2.0 was flashed. But maybe you never flashed v2.0. ;)
So, here you go:
noIQagent.zip
Also, theme reTouched includes the noIQ tweak if you are interested.
(Just figured I'd through that out there......LOL)
Thankyou ill give it another shot when I get out of work.
You're right I flash only the latest version of ReBorn ROM V2.1
I've deleted the old IQagent patch file, but now I have others I'm wondering about. I have upgraded through many ThundeROM and Nameless/Reborn versions. Can I delete the following from the root of SDCARD? I'm guessing their left from the Thunder days.
BuildPropDeluxe.zip, BuildProp-Stock.zip, and BuildPropStock_No-Jit.zip?
Thanks! That Recovery Flash screen is getting a bit lengthy...
Loving this ROM and about to try ReTouched.
Status
nettirb
