ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
flashed straight over reborn 2.1, to 2.2.1, while I shaved this morning.
no problems, just have to re-flash my boot animation. all apps are good to go.
feels snappier, will test on morning commute.
Anytime I have changed the name of a backup it never works. Thats been since day 1 of having a rooted optimus s .
sent from my FANBOI EVO 4G !
I'm still currently on Reborn 2.0 can I flash over or must i wipe data to be on v2.1?
Also, Im on swype beta 3.6 what happens when I flash this ROM to swype?
I have only had one renamed nand give me an md5 mismatch. That was because when I renamed it I had a space in the name. I took the space out and everything was fine. Wasn't sure if the ones who were having issues used any spaces or special characters when they renamed it. Just wanted to throw it out there in case they did.
Reactions: Thabyrdman
You don't have to but I would advise to wipe everything. Swype has been moved to you can remove it once u flash over to the new reborn so u are able to use the new swype
Reactions: ens04
You know what you may be right. I think I did use a space or a special character lmao! Good call
Yea same here, Now all i do is add in ( ) stock 0r 2.1 at the end of name so that way i know what each nandroid is and i know what to earse to make it work.:)
good to know will give that a try!!!
Thank you...Good to know when I get home ill make sure to thank you...
Sent From My Super Awesome, Over The Top Optimus S.........Tapatalk......
Do the themes still work with the upgrade?
edit... already answered in the theme post. They do!
Cool to see other Michigan users in here, Jessia. I'm from the thumb, myself! :-D
Anybody else from the Mitten?
posted this in the themes thread as well, but with reborn 2.2 i'm getting the send button cut off while using the reTouched theme along with the stock font zip, just a heads up. Don't know if there is an easy fix.
Anyone else not able to flash 2.2.1? It says its bad or something like that when I try to flash it, but 2.1 flashes fine. Tried wiping everything as well.
Status
alexajamez
