Prior to posting, please ensure you have read
the rules for ROMs. Following these is not an option, it's a requirement both for developers and people using developers products.
STOP and read the above
[info]This ROM is a combination of the greatest features of ThundeROM and nROM to create one high performance ROM that is very reliable.[/info]
Standard Disclaimer:
[warn]
Requirements:
Your phone must be rooted, have a custom recovery, and be running the VD baseband. No exceptions. Anything less and the ROM won't work properly. To check baseband Menu > Settings > About phone > Baseband version should end with VD. This is a ROM thread, any questions pertaining to rooting should go to the
[How-To] root thread. If you are already rooted and just need to update your baseband, go to
[Hot-To] Update Baseband.[/warn]
Features/Changelog:
Code:
v2.2.1
+ Application
- LG mms themed black - huge props to jstntp, I wouldn't have been able to do this myself
+ Other
- Contact editing bug fixed.
v2.2
+ Technical
- smartass cpu governor added to latest picasticks kernel and set as default
- no-op i/o scheduler enabled in kernel
- enabled "ameuter radio support" in kernel - Maybe a step closer to radio functionality?
- fully optimized all apks (zipaligned, png-optimized, etc.)
- many tweaks to improve battery life
+ Visual
- EV icon changed to 3G
- black background for messaging app (can be toggled back to white).
+ Application
- themed hotspot widget to replace wireless tether app - thanks Harold Muller
- all downloads enabled in browser and gmail by application - thanks HwkRbbt software
- cm mms (messaging app with black background and many additional settings)
- voice mail client added - when you first boot up your phone you will receive 2 text messages because of this app. Just ignore them)
- added spare parts for battery trouble shooting and custom transition speed
+ Other
- swype moved to data for easy removal in light of the new beta
- removed privacy menu from settings.apk - thanks mmarz for the guide
v2.1
+Technical
- changed up the tweaks99 script and build.prop to improve battery life.
- removed noIQpatch. Too many people had problems with it.
v2.1
+Technical
v2
+ Technical
- picasticks v7 kernel - thanks picasticks
- changed governer to ondemand
+ Visual
- added themed notification power widget - thanks JsChiSurf (for the mod) and 96blkgsr (for porting advice)
- increased transition speeds - thanks k0nane (for the script)
- removed usb debugging notification - thanks jholm7 (for the tip)
- gps, music notification, and hot spot icons changed
- added boot animation
- network name changed to "Reborn ROM"
- themed genie widget
- removed vm button in dialer and made call button larger. Long press 1 for voice mail
+ Application
- removed file expert. We recommend that you download it from the market for free
- power control application for controlling some toggles - thanks JsChiSurf
- removed spare parts because transition speed is set to fast by default
+ Other
- fixed ringtone being silent after fresh flash
- named ROM. Nameless ROM was already taken
- noIQagent.zip now pushed to SD card
- fixed missing widgets in LG launcher on fresh flash
- set up wizard on fresh flash
v1
+ Base
- Built off VD ([URL="http://www.lg.com/global/support/opensource/opensource.jsp"]source[/URL])
- removed bloatware ([URL="http://forum.androidcentral.com/lg-optimus-s-rooting-roms-hacks/78229-rom-nameless-rom-v1.html#post838626"]Sprint apps can be downloaded in post #2[/URL])
+ Technical
- hosts file to block ads in apps
- busybox
- sysrw & sysro commands
- zipalign at boot
- dalvik cache to cache mod
- gumbo script - [URL="http://forum.androidcentral.com/members/1663.html"]Thanks gbhil[/URL] (some values based off our existing work, some based off [URL="http://forum.xda-developers.com/showpost.php?p=12205635&postcount=1"]franciscofranco's work[/URL])
- many build.prop edits (some values based off our existing work, some based off [URL="http://forum.xda-developers.com/showpost.php?p=12205635&postcount=1"]franciscofranco's work[/URL])
- removed [URL="http://forum.xda-developers.com/showpost.php?p=11763089&postcount=3"]IQ agent[/URL] completely ([URL="http://www.mediafire.com/?ci1r87csejbovjn"]requires patch[/URL])
+ Kernel
- picasticks v6 kernel ([URL="http://lyncd.com/2011/03/android-kernel-overclock-optimus/"]source[/URL]) - [URL="http://forum.androidcentral.com/lg-optimus-s-rooting-roms-hacks/73874-kernel-picasticks-oc-kernel-built-lg-source.html"]Thanks Picasticks[/URL]
- overclocked @ 748 MHz w/ interactive governor on boot
- able to be OC'ed up to 864 if your phone can handle it
+ Visual
- custom notification icons for SMS/MMS, Email, Gmail, Gtalk, calendar
- custom dialer
- hybrid theme of ThundeROM and nROM
- 10 HTC wallpapers (CDMA Hero)
- 8 Android Central wallpapers - [URL="http://forum.androidcentral.com/wallpapers-ringtones-themes/12470-scodoublets-random-droid-wallpaper-emporium.html"]Thanks scodoublet[/URL]
+ Application
- LG launcher - espresso themed
- File Expert file manager - [URL="https://market.android.com/details?id=xcxin.filexpert&feature=search_result"]Thanks Geek Software Technology Inc.[/URL]
- HTC IME mod keyboard -[URL="http://forum.xda-developers.com/showpost.php?p=6180259&postcount=1"]Thanks gogol[/URL]
- wifi tether v2.0.8 - [URL="http://code.google.com/p/android-wifi-tether"]Thanks Harry and team[/URL]
- music mod music player - [URL="http://development.piratemedia.tv/author/admin/"]Thanks Eliot Stocker[/URL]
- terminal emulator ([URL="https://github.com/jackpal/Android-Terminal-Emulator"]source[/URL]) - [URL="https://github.com/jackpal/Android-Terminal-Emulator/wiki"]Thanks Jack Palevich[/URL]
- TWS fix application - [URL="http://forum.xda-developers.com/showpost.php?p=11076756&postcount=1"]Thanks lotus22[/URL]
- force roaming application
- app widget picker ([URL="http://code.google.com/p/scrollablecontacts/source/browse/#svn%2Fappwidgetpicker%2Ftrunk"]source[/URL]) - [URL="http://forum.xda-developers.com/showpost.php?p=8107962&postcount=1"]Thanks boombuler[/URL]
- Spare parts - [URL="http://forum.androidcentral.com/members/1663.html"]Thanks gbhil[/URL]
- updated Gapp
- alarm clock to replace deskclock
- modded email client - EAS bypass
+ Other
- tweaks script build.prop editor ([URL="http://forum.xda-developers.com/showpost.php?p=9718502&postcount=1"]Thanks ruigui[/URL])
- reboot mod
- voice control button mapped to call
- only power button wakes phone
Instructions to use Reborn ROM:
*MAKE A NANDROID BACKUP BEFORE FLASHING. THIS IS NOT AN OPTION.*
1. Download
Reborn ROM. Do not open it, do not extract it, do not rename it.
2. Place on root of sdcard.
2. Reboot to recovery.
3. Wipe data, cache, and dalvik-cache.
4. Flash Reborn ROM.
5. Reboot and enjoy!
6. Make sure you check out
this thread for some awesome themes!
Note: The fast transitions will not take effect until the phone is rebooted after the first boot of a fresh flash. After that first reboot the setting will stick.
Known Bugs specific to this ROM:
- When booting up after a fresh flash your phone you will receive 2 text messages because of visual voice mail. Just ignore them.
- Our launcher doesn't play nice with different LCD density's because the PNG's do not scale. Default density is 160. If you'd like to change your density you need to use a different launcher/home replacement. This is not something we are looking into changing.
After a full wipe (data,cache,dalvik), when you flash the first time the launcher will try loading a couple widgets we didn't include. Drag the words "Problem loading widget" to the garbage can as if you were deleting the widget. Will only happen after a full wipe and flash. This is something we're looking into either clearing those widgets from the launcher or adding them in to the ROM, not sure. -fixed in V2
When finishing adding or editing a contact the application will force close, but fear not the change still occurs. I'm working on a fix for this. - fixed in v2.2.1
Reporting an issue:
If you identify an issue that's not already listed in the bugs section above please do the following.
PLEASE DO NOT REPORT GENEREAL ANDROID/SPRINT/FROYO/LG BUGS.
- If you are running a custom kernel do not report the issue until you have gone back to the kernel provided with the ROM, and can duplicate the issue.
- If you are running a task killer/battery saver/app smasher etc etc.... do not report the issue until you have removed the task killer, rebooted your phone, and can duplicate the issue.
- If you are having an issue with any app that you download from the market or any other source, please do not report the issue to us. There is a very good chance this has little or nothing to do with the ROM and everything to do with that specific app. You should check to see if others on similar ROM's are having an issue with that app. Check to see if the app dev has a bugs list. check to see if the app is compatible with your version of Android. Email the app dev to see if they are aware. Uninstall and reinstall the app. etc... etc... etc...
- If you are not on our newest version of the ROM AND did not do a full wipe prior to flashing, do not report an issue until you have done so.
- Do not use this thread as your personal help forum. We understand you may have questions about things that are unrelated to the ROM but you want them answered quick so you post them in here. These types of questions will be moved out of the thread, which requires us to manually intervene, please save us the time. You will notice that the same people who are active in this thread are active in every Optimus thread. Post your question outside of this thread, in the general area for assistance.
EX: How do I mount or unmount my SD card when i connect to a PC? This is a legitimate question, but has nothing to do with the ROM.
- Duplicate the issue. If you don't know how it happened or how to do it again, neither do we lol
- Have you rebooted your phone and after reboot can duplicate the issue? If not please do.
- Post very detailed instructions on how to duplicate the issue, for example:
-Click Menu > Settings > Display
-Un-check "Auto Rotate Screen" then the phone punches me in the face
Credits & Thanks:
- Many credits are given in the changelog. Please take a moment and read them.
- The AndroidCentral Family
- Beezy and KSmithInNY for their work on ThundeROM
- untermensch for his reboot mod tutorial.
Donations:
Not expected but humbly accepted.
To Donate to Nick
