ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
You are right. It seems like the Mms.apk from that thread doesn't have that issue. Was this fixed or was this due to the PNG optimization that was done on this ROM? Hmmm...
I modded the mms.apk for nick and I messed up the xml file that controls that send button. It is now fixed in that link in the themes thread as you can see. Had nothing to do with the png optimizing nick did.
Reactions: jondevere
Re: [ROM] Reborn ROM v2.2.1 - 6/23/11
working great so far, just installed right over older version, didnt delete data or anything
I keep getting a force close when trying to pair bluetooth with motorola roadster. Worked great in 2.1.
I'm also having the same problem on bluetooth devices that require a passcode. It seems to FC when in calls the passcode window. On those bluetooth devices that don't require a passcode, it pairs fine.
It seems there is an issue with Bluetooth pairing, others were posting about it earlier today. Nick has stated he will look into, in the meantime I'd probably nandroid back to 2.1 (assuming you have a backup) if you need the bluetooth. Otherwise I'm sure Nick will get it sorted quickly.
Edit: Nick's words are better than mine, few pages back:
Maybe one of the bluetooth applications was broken during png optimization or maybe my modified picasticks kernel took a poo on bluetooth. I'll look into it.. next week or so.
Thanks for the report.
Has anyone else had problemz with their phone lagging? I did not have lag problemz on 2.1. Maybe the custom governor?
I will adress the governor issue tomorrow, sorry guys.
I have noticed the lagging problem initially throughout the thunderom series now up to Reborn. When you first flash, USB debugging is enabled. I always disable USB debugging and the speed immediately picks up and, in my opinion, appears to be normal.
Just curious, what exactly is the 'lagging problem'?
I have Reborn for a while now and haven't experienced any lagging problems...
Have it. On my phone right now. Can't post a link from my phone tho....
Why do you want the old file?
Still using Reborn v2. Not sure which version is the best upgrade at this point if people are experiencing issues with 2.2.1. Unless that'll all get sorted by the end of next week.
I'm a rooting and ROM n00b and was able to install this today and it works splendidly :)
thanks!
The only difference between the two is listed in the change log. Different mms.apk which fixes the contacts editing bug. Other than that, no difference.
Interesting, after 7 hours the battery only dropped 1%... so far so good :-)
I am phenomenally curious as to what you have running (services and programs) and how you are getting that good of battery life. Care to share?
The phone is usually on WiFi, with email checking on push.
Don't do much except look at emails once in a while... could be because I haven't wiped batterystats.bin after I flashed from 2.0 - although I don't know if this will make any difference.
Now down to 98% after 8.5 hrs... will see how long this lasts... lol
OK, I have one question....... How in the hell did you fit two batteries in there. LOL
JK!!!........ but seriously, did you see similar results before you flashed 2.2.1?
All I can think of is that you are not telling us this...
You ONLY use this for email and wifi access. NOT as a phone for everyday use. Cuz I can piss more battery life than that LOL.
Yes I was adding spaces in my backups. Never thought much about it til it was asked. That was why mine were messing up im sure.
I'd bet money that's what caused your pain... ;) and Obviously, you're not the only one who's done that...
Status
LuisLikesAndroid
