ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Re: [ROM] Reborn ROM v2.2.1 - 6/23/11
Not sure if this was a common problem but after updating to 2.2.1 when i try to pair a Bluetooth device it gives me a FC, is there a solution for this? Thanks
The problem is known and when Nick has time I'm sure there will be and update to fix it.......
Sent From My Super Awesome, Over The Top Optimus S.........Tapatalk......
Thanks for the update. Your quick response is much appreciated.
Re: [ROM] Reborn ROM v2.2.2 - 6/28/11
What baseband are you on? Sounds like that may be your issue. You need vd
EDIT. . . . Didn't reload sorry for duplicate answer :)
Sent from my PC36100 using Tapatalk
How can u update to vd without losing root? Do u just force flash to vd using LG Updater tool?
just finished flash of 2.2.2 - Booting up now...
Alright, hopefully this is my last release for a while so I can work on gingerbread, but keep the bug reports coming.
v2.2.2 released.
Thanks Nick! Going to try it out. U da man! And thanks also to all the other developers involved with this ROM. :)
I'll try this out today and test the battery life. I really like the layout and customization available for Reborn but I don't want to charge my phone twice a day lol.
Not to burden of bad news....The factory reset is back on the menu in 2.2.2.....
I didn't really think it was bad news just wanted you to be aware of it....
this is my first time updating a rom and I seem to have done goofed. I wiped data/factory reset, cache, and davik cache and then flashed the rom as well as my startup animation and the button wake zip all at once and everything was a-ok until I reinstalled titanium backup. it wouldn't let me open and didn't appear under "downloads" in the launcher too. I thought that was weird, rebooted the phone, uninstalled and reinstalled and it was still being wonky. superuser was still on there but I was worried that I somehow lost my root or something so I then tried to revert back to my last nandroid, it would go to the lg screen and then back into recovery.
luckily my nandroid before that one seems to be ok, so after I restored it and made sure it was peachy, I restarted the whole rom flashing process all over again (with the wiping and all) but only flashing the rom and nothing else. just tried to install titanium backup from my apps on the market again and while it installed, it's still not letting me open it. and it's still not in the menu. so somehow I am messing something up...
also, I don't know if it's related or not but it says "3G" instead of "EV" on the 3G thing again. both on my flashed 2.2.2 and now on my nandroid backup.
v2.2.2 released.
Is this file larger...or somehow different than the other zip files. I am unable to download it onto my phone. Keeps telling me that "Download unsuccessful. Download interrupted. It cannot be resumed."
Any ideas?
Does it let you open titanium on nandroid that wasnt goofy?
This was a change........Look at the changelog in the OP for more info. that was updated....
Reactions: digitallove
This was a change........Look at the changelog for more info. that was updated....
ah, I checked the changelog but didn't see it. and while I expected it was a change, since my nandroid had 2.2.1, I was surprised to see that change on there too. but I deleted the 2.2.1 zip off my sd card, so that could be why.
and yes, it does let me open titanium not the not goofy nandroid.
Any ideas?
It's about the same size.....I had no problem downloading from my phone......Are trying to download from your phone? If so try downloading on a pc then placing on the root of sd...
Status
gruptysh
