[ROM] Redemption Rom v2.0.2
i just downloaded the 2.0.4 rom also and i can say its pretty bad ***. the only thing i noticed thus far is the htc messages widget on the home screen, when you click the 3 lines to pull up all messages it doesnt work. you have to click on individual message and then menu all messages. a lil annoying but i can live.
also is there a way to delete dspmanager,es file, and spare parts, i have no need for them and when i go into applications, its unable to uninstall. sorry if its a noob question. thanks any way for your hard work.
You can remove them through adb
I am having issues with mutimedia message when I try to open them it says process has stoped unexpectedly ?
hey lou is there any way i can get the default camera, and mms app? itd be much appreciative. if anything just the mms app cuz of the home screen widget
Menu>Settings>Applications>Manage Applications Go to Messages and Force Stop and clear data. Then try sending a MMS to test.
check out the thread at xda there is a zip with all removed apps.
yeah the zip file just all the bs apps like teeter and what not. the files for the camera and mms arent there lol, all well
yeah on a lighter note my adb skills are getting better. lol learned that you can list all the apps and pick and choose. what can i say im a noob on a learning curve.
so rumor over at xda is that 2.0.5 is round the corner. pretty stoked to see what changes are gonna be added. to update would you have to do the whole wipe and flash over or is there a quick update way?
Thats the word. Did you see Lou's teaser pic? I asked the same thing and was told that many have just loaded up the new version without wiping with no issues, however I have still been doing full wipes on every new ROM. Just in case.
nah im not a memeber at xda so i couldnt see the pic. i just saw people writing about it. hows it look, any different
Love the Rom! I am running in to a weird issue. So I flashed backup assistant back on so I can retrieve my contacts. Now I want to sync them to Google. When I go to accounts & sync and choose Google, I have the option to sync contacts as well. So I keep that checked but nothing sync over. Any ideas?? Is this a bug with the Rom?
Thanks again all!!
Thanks again all!!
Solved... I exported the phone contacts to the SD and imported them to Google. Then synced. Now only view Google contacts
Redeem yourselves and check out lou's new rom. It is the sweetest thing. It is called redemption revolution. On xda under incredible development
Sent from my ADR6300 using Tapatalk
Yup! Lots more going on over on the xda threads, as usual! ;)
Darek
