[ROM] rubiX Focused 2.0.1: UPDATED
thanks worked perfectly. can this be done to dialer? I hate the dialer in this Rom
Sent from my DROIDX using Tapatalk
I have not being able to find a way to do this. From what I have found is that no you can not. :/
The battery lasts quite allot with this rom. I got 23hrs with moderate use yesterday, but I do have a 3500 battery on board. But still.
Original thread located here: rubiX Focused 2.0.1: UPDATED - Droid Forum - Verizon Droid & the Motorola Droid Forum
Thanks to @Drod2169 for his continued work on this.
Please read and follow the install instructions.
YOU MUST BE ON 2.3.340 OTA FOR THIS TO WORK
ALSO NOTE: IF YOU INSTALLED THE NEW TRANQUILITY, THE TOOLBOX WILL INSTALL UNLESS YOU SBF BEFORE INSTALL. THIS IS TRUE FOR ANY ROM, NOT JUST RUBIX.
IF YOU USED THE NEW SCRIPT, YOU MUST REBOOT AFTER INSTALL AND INITIAL SETUP
This script runs on first boot to scan the SDCard rubiX Folder for apps. If they are there, it copies them to /data/app and corrects their permissions. Reboot for this to take effect.
YOU MUST wipe data before install.
Change Log for 2.0.1
  • Adjusted scripts for better functionality and less errors.
  • Added the option to set whichever governor you'd like on boot (NOT TESTED)
  • To do this: use root explorer to get to /system/etc/init.d
    long press on 01cpu
    select open in text editor
    change the variables at the top
    ONDEMAND=1
    CONSERVATIVE=0
    INTERACTIVE=0
    is the stock setting. To set one at boot, simply change ONDEMAND to =0, and one of the other two to =1
  • Custom ringtone fix (credit to kejar31)
  • Potential Programming menu fix (someone test please, i'm not sure)
Change Log for 2.0:
  • Sysctl.conf adjustments:
  • Changed vm.dirty_background_ratio to 70 from 60
  • Added rm /dev/log/main for extra performance/free memory
  • Changed NO_NEW_FAIR_SLEEPERS to NO_FAIR_SLEEPERS; this was a typo, as there are no new fair sleepers in the dx kernel already.
  • Cleaned up the /system/app folder
The following market apps were further removed:
  • Talkback
  • Kickback
  • Soundback
SCRIPTS: Credit to Fabulous, JRummy, Sephtin and Drod.
Usage:
Open Terminal (download from market if you don't have it)
su to grant SuperUser access
command w/arguments
ie gallery -2d
  • adblock: block or view ads
  • apps: run the script for directions. If you choose restore, you must reboot after for it to take effect
    backup: backs up all of your user apps. backup -bk is the correct way to run the script
  • calc: remove/restore the calculator
  • carhome: remove/restore the car home launcher
  • dxeye: remove/restore the DX LWP Please note that this is removed by default, and placed in /data/rubix run the script to restore.
  • email: remove/restore the email app
  • fixperm: fixes permissions (credit Koush)
  • gallery: switches between the 2D (credit to Cyanogen) and 3D AOSP Gallery
  • genie: remove/restore the news/weather app
  • office: remove/restore QuickOffice: Please note that this is removed by default, and placed in /data/rubix run the script to restore.
  • sys: write the system read/only (-ro) or read/write (-rw)
  • zipalign_apks: zipaligns all the apps in system. Unnecessary since this is ran on every boot!
Governors
Added new Interactive and Conservative kernel scaling governors (credit Milestone team)
This is a Droid X first. These two governors bring a big difference to the table; here is what they do:
(Credit Cyanogenmod GITHub for this, source is here: https://github.com/CyanogenMod/cm-ke.../governors.txt)
Interactive:
  • significantly more responsive to ramp cpu up when required (UI interaction)
  • more consistent ramping, existing governors do their cpu load sampling in a workqueue context, the 'interactive' governor does this in a timer context, which gives more consistent cpu load sampling.
  • higher priority for cpu frequency increase, rt_workqueue is used for scaling up, giving the remaining tasks the cpu performance benefit, unlike existing governors which schedule rampup work to occur after your performance starved tasks have completed.
Conservative:
The CPUfreq governor "conservative", much like the "ondemand" governor, sets the CPU depending on the current usage. It differs in behaviour in that it gracefully increases and decreases the CPU speed rather than jumping to max speed the moment there is any load on the CPU. This behaviour more suitable in a battery powered environment. The governor is tweaked in the same manner as the "ondemand" governor through sysfs with the addition of:
freq_step: this describes what percentage steps the cpu freq should be increased and decreased smoothly by. By default the cpu frequency will increase in 5% chunks of your maximum cpu frequency. You can change this value to anywhere between 0 and 100 where '0' will effectively lock your CPU at a speed regardless of its load whilst '100' will, in theory, make it behave identically to the "ondemand" governor.
down_threshold: same as the 'up_threshold' found for the "ondemand" governor but for the opposite direction. For example when set to its default value of '20' it means that if the CPU usage needs to be below 20% between samples to have the frequency decreased. Basically, this means more speed and battery life control
Adjusted 01cpu for a better sampling rate if the new conservative governor is found.
Added script: gov
gov allows you to control which governor you use; ondemand, conservative, or interactive. The function is:
gov -ondem for the ondemand governor
gov -cons for the conservative governor
gov -inter for the interactive governor
Alternately, these can be changed via SetCPU or Droid Overclock.
To remove data throttling, click this:
rubiX Focused 1.9.7, back and better than ever - Page 3 - Droid Forum - Verizon Droid & the Motorola Droid Forum
Credit to Plower.Net
How to install:
Download
Place on SDCard
Bootstrap Recovery via Bootstrap App
Reboot to Clockwork Mod Recovery
Wipe data/factory reset
Select install from sdcard
Choose zip from sdcard
select rubiXFocused2.0.zip
Select yes
Reboot
Enjoy!
Download from the original thread:
Original link is broken. Where can we download 2.0.1 updated?
Mohamed_1rashad
