[ROM] t0ast3d de1ight FroYo Sense 7-31-10
so we have to wipe and then flash this? how do i get my apps back after that? just load the back up from titanium?
Yeah, but I recommend My Backup, it will back up everything + data and you don't have to reinstall them one by one.
No more wipes after this though!
T0ast for president? Haha, whenever someone can root this damn 2.2 ( I know I shoulda waited I'm dumb) this rom is first on the list. Keep up the great work toast!
I love the rom. But I didn't realize I was going to go from 8mp all the way down 3mp on my camera. Will that be fixed soon?
Sorry about that, you can flash any kernel with the rom if you want it raised..
but yes, a fix kernel will be soon.
toast, random question. I wiped and flashed the 1.1 ROM. but then i did a nandroid restore of my data from the 1.0 ROM (cuz im a rookie) and then reflashed the 1.1 on top of that. and everything is working. but i dont know if that was really the correct way to do it. and could that potentially mess anything up?
Doing it that way can cause fc's, but if everything is working, you should be good. If you stick with my ROM for awhile, from 1.1 on up, you will not have to wipe at all (:
is there anyway to back up the icon positions on all of my homescreens without doing a nandroid back up? i'm going to wipe clean and reflash again
its underclocked. and new kernel doesn't work. the one I used with the 1.0 Rom.
Sent from my PC36100 using Tapatalk
yeah. I like the 500 limit. but some reason it lags more than enough. so could it be the kernel? cause once I flashed the other kernel. it said 998 then as soon as I went to of it it dropped its limit to 500
It shouldn't lag at all.. What are you noticing?
pinch to zoom will often take an extra second to work. my menu doesn't pop up instantly. and apps load longer. like text and gallery. don't know if its just me. any ideas. these happen when I even close almost everything.
Idk, I'm having no problems what so ever like that. Mine's super fast.
Can someone else input on this?
hey toast, i find this new rom running smoothly i have had no problems like the one stated above, but i did notice something.
it says my voicemail app wants to be updated but every time i try it it says that it couldnt install or something like that, any ideas why?
toast, i was wondering if i could get a pic of the background you put on it? when i reinstalled everything with titanium backup it took out that cook background. Thanks
tsmtoolpro
