[ROM] t0ast3d de1ight FroYo Sense 7-31-10
Well I decided to root and drop the t0ast3d de1ight ROM like it's hot and sure enough my memory decides to work and I remembered there's no way to root :( Either way I should be getting my workers comp check tomorrow and I'll donate anyway. Hopefully someone finds a way to root 2.2 already!!!
Ah, that sucks!
but thank you for the donation.
It's just a matter of time!
Hey toast. My phone went completely nuts. Had to restore your previous rom. Don't know what happened. It froze and just had issues with everything I did. I didn't touch the cpu. Left it at 549 and it all started when I tried to record video the thing didn't let me record and then started freezing up on me when trying to exit and access other apps
Sent from my PC36100 using Tapatalk
Damn.. I'm sorry.
Maybe it was a bad flash or something. If you wanna try to stick with me, you can try redownloading the ROM, if not it's cool, wish luck to your phone and you either way!
hey toast, i find this new rom running smoothly i have had no problems like the one stated above, but i did notice something.
it says my voicemail app wants to be updated but every time i try it it says that it couldnt install or something like that, any ideas why?
Just something to do with Sprint I'm guessing. I'll have the updated voicemail in the next build
toast, just wanted to let you know that after a couple of days your rom has ran smoothly except it gave me an FC to one of my apps but that went away i think. at least it hasnt appeared again. but thanks again for such a smooth rom. cant wait to see what the next release has to offer
Was it gapps? It happens sometimes but doesn't/won't affect anything.
No problem man
Hey toast, i was wondering. does wifi tethering work with your 1.1 rom? i was trying it out and it didnt even come up as a option for connecting. i have 2.0.5 pre8 which is suppose to be able to connect with froyo roms. so yea just wondering if i messed something up.
I'm already looking into it. I've had the same problem. I'll let you know what I find out here pretty soon. I'll be off work in a couple hours.
Experiencing the same thing. Current version on this ROM is V.5.1.0.32.
Outside of that, everything else works *flawlessly*
Edit: Check that. None of the non-oem Evo animated screen savers work.
Hey Toast, My phone is saying that I have an optional voicemail upgrade, Every time I try to do it, it says Application not installed? Anyway to update this or a way around it?
Toast is dead. ha nah but he left these forums because he was sick of people, flaming childish stuff.
ANYWAYS. search around, i dont personally know the fix for it but it happens on other roms also, try searching here first then if nothing, try XDA
From what I know unrevoked3 doesn't unlock nand which is required to flash a custom rom.
:confused: Seriously dude...
Unrevoked Does let you Flash Roms... Thats a completely False Statement...
UnRevoked just does not Flash the Eng-HBoot Needed for Certain Roms...
Besides that your good...
I Recommend SimpleRoot Honestly... None of the BS
SamuraiJack1981
