[ROM]TeamVenum-Wicked Sensation JellyBean V 3.0 [MB1] ROM
Status
Not open for further replies.
Re: [ROM]TeamVenum-Wicked Sensation JellyBean V 1.3 [OFFICIAL] ROM
Anyway this can be added as a splash screen
I could do it but would have to do one of two things. The image needs to be almost twice as large (720X1280). I could blow it up but it is already starting to pixelate. Or I can paste it into the proper sized image and leave a substantial border around it.
Or you can find a larger image.
Just got back from Vacation....Mexico was great....I see I missed 1.3?? Do I have to update?
Is there really a way to get your phone to charge faster? I thought I read that somewhere....
You never have to update.
If you can paste it as you said... Try that, but in the meantime I'll check to see if i can find a larger image
If anyone has flashed 1.3 Twisted Pink Theme, the alarm clock force closes. Please download the fixed alarm clock in the kuban updater.
Skun.. the update and fixes within the kuban updater are just in case the actual app are not working?
Yes and no.
Many of the apps in this Rom are themed. If the playstore tells you of an app update and it fails because of a signature error, it is most likey because the app included in this Rom is themed. You will not be able to install these updates through the playstore without first uninstalling the themed one.
Dazed is pretty good about updating these. When an app is updated on the play store he themes the update and puts them in that portion of the updater.
So installing the updates is optional.
The fixes are more specific. Such as the twisted pink alarmclock. It force closes. But it is specific to the twisted pink theme. So unless you are having issues then I would bypass the fix.
Does that answer your question?
Can I update from 1.2 to 1.3 just using my phone or should I use my PC?
It's a full Rom. I would use the computer.
This will be my first attempt at flashing a rom so I'm hoping not to screw it up. I'm wondering do I need to first flash twrp since I am on cwm? then follow the instructions for the rom, then flash the kuban updater fix?
Is there anyway to get the TW widgets to work with the 5x6 TW?? It cuts off and won't resize.
If you flash version 1.3 you won't need the fix. It has the newest version that rujelus has done. You can flash the rom with either recovery, but if you want the best experience with the updater I suggest TWRP.
Can't really help you on that. I never use TW Launcher. Sorry.
Yes, just wanted to be aware... I have gotten a couple of signature errors but now that u explain it, i know how to go about it... thanks
I just picked up my son for the holidays, so I will be taking a little break from Android. Hope everyone has a very Merry Christmas and a Happy New Year!!!!
For those that want to remove the brightness slider from the notification bar you can now do it. Dazed put this together for you. This will work on Wicked Sensations v1.3, Anakonda theme v2 and Twisted Pink v2. Just download and flash in recovery. Always back up to be safe before flashing.
Remove Brightness Slider - Download Here
Status
Yageornba
