[ROM]TeamVenum-Wicked Sensation JellyBean V 3.0 [MB1] ROM
Status
Not open for further replies.
Re: [ROM]TeamVenum-Wicked Sensation JellyBean V 2.1 [OFFICIAL] ROM
Lol
The 1st question about the loudness tweak is the main one I'm hoping gets answered. The rest is just me wanting to check out other features and see if I like em enough to use. :)
It has the sound hack in it still along with Awesome beats. Awesome beats doesn't work with all music players, but works with Google Music and another music player i use. The sound hack isn't extremely loud but it definitely gives it a boost.
The other features i haven't really checked out. Try them and see and let us know.
Thanks for the quick response Dazed. Good to know about the boost.
As for the other features. I couldn't get most of them to work which is why I was asking. Could very well have been user error lol
Samung / Sprint trying to roll out new update that fixes the screen lock bypass hack through the emergency dialer. Will there be an update with this rom?
There will be no update for MA5 or MB1. I'm not sure about anything after that. On the note that was fixed with a kernel update. If that is the case with the gs3, then it would be possible to fix the exploit by flashing the kernel alone.
I can easily pull the kernel and put it in a flashable zip for anyone who wants it.
if it will fix the sprint update message i'll test it.
If you want to stop the update notification look below for the cure. This is for wicked sensations 2.1 only.
If you update to v2.1, then flash the link skunk posted earlier, you won't get the notification. I'll try to link it again when I get home.
Modified build.prop for Wicked v.2.1. http://d-h.st/GKG
Just download and flash in recovery on Wicked or any of my themes. Don't use on other roms.
Re: [ROM]TeamVenum-Wicked Sensation JellyBean ROM
Works, my phone is not nagging at me for the update. Also i heard the sprint update bricks some applications. Way to go guys! LLOLL!
I'm new to this rom, running 2.1 and had a question about the pulldown images available through the Kuban Updater. I downloadeda couple but it keeps telling me the MD5 doesn't match. What do I do to use these?
Tell to install anyway and it will work. However I have noticed that with the newest TWRP recovery 2.4.3 you will have to flash manually. The older version did it by itself.
Thanks seanski. I'm still on an older version of TWRP (2.3.1) so it did all the work for me
That's what I stay on is TWRP 2.3.1 and it works great with the updater. I've had nothing but issues with the newer versions.
I have TWRP 2.4.3 and have had no problems with The Kuban Updater automatically flashing. I'm curious as to why it works for some and not for others.
I guess hindsight is 20/20. Had I known I wouldn't have updated it...lol
Kieth, that amazes me also.
Skunk has the link for TWRP 2.3.1 in post #1.
Sent from my Nexus 10 using Android Central Forums
Anyone else on this ROM having a problem with google navigation crashing? I'm not saying it has something to do with the ROM, but I'm just trying to narrow down where the problem is.
After the arrow starts to move, it freezes, and screen goes black. But the voice guidance is still there, and still listed as a running app in the pulldown menu. After clicking on it, in the pull down menu, that's when I get the "Unfortunately, maps has stopped"
I'm hoping someone else has/had that problem too. This was happening on the previous version of the WS ROM too.
And again, not blaming the ROM for this. I've been Dazed's biggest fan, lol
I use my phone all day, every day for gps navigation when I'm working. And occasionally google maps does do wonky stuff. Trying to remember, but I think it also did it a few times when I was stock.
TBH it never did the black screen, it would just freeze up. I did notice it usually happened when I had really a bad data signal
Like EZ, I use mine all day for work. I haven't had any problems. I used to have all kinds of problems when I ran custom kernels.
IJS. Clear your ram. And try to over clock a bit.
Just wanted to throw a shout out to Dazed. WS is the best rom I have used for my S3 hands down. Just updated to 2.1, flawless. Thanks a ton!
Sent from my Wicked Anthraxed Smoky S3 :)
Status
r3dpuk3
