[ROM]TeamVenum-Wicked Sensation JellyBean V 3.0 [MB1] ROM
Status
Not open for further replies.
Re: [ROM]TeamVenum-Wicked Sensation JellyBean V 2.1 [OFFICIAL] ROM
First, love the ROM... it is the best ROM I have ran on this phone!
That being said, I am trying to figure out how to add a Samsung account. There is no option for this, but a Samsung account is needed for the remote wipe tools provided by Samsung. Is there anyway to add this type of account? Any help is appreciated!
Edit: On WS 2.1
Just wanted to throw a shout out to Dazed. WS is the best rom I have used for my S3 hands down. Just updated to 2.1, flawless. Thanks a ton!
Sent from my Wicked Anthraxed Smoky S3 :)
Thanks and glad your enjoying it. Don't really have any new mods that I want to add, but I have been working on some new theming touches. Hopefully get something put together in the next week or two. Here is the new dialer I've been working on.
http://img.tapatalk.com/d/13/03/11/u3y8ugyn.jpg
http://img.tapatalk.com/d/13/03/11/gapejysu.jpg
That dialer is awesome! Can't wait to flash it in the AnaKonda theme!
Sent from my Nexus 10 using Android Central Forums
Anyone? Bueller.... Bueller.... Bueller?
Edit: On WS 2.1
Look in the Kuban updater, under removed apps. You should see the samsung stuff you need to re-add.
would anyone be kind enough to tell me how i can go back to the blue theme (I believe it called blu Kuban) if I tried another theme(gray theme). I seem to be able to switch between the three themes in the theme folder(pink, gray, and orange/green), but cannot locate a way to go back to the original them I saw when I installed the theme.
I may be wrong, but I believe you just need to flash the ROM again to go back to the original theme.
I actually had the same idea, but needed someone else to come to the same conclusion before I attempted it. So I guess Ill give it a go.
thank you
thank you
That is exactly how to get back to the blue theme.
Sent from my GS3 running Wicked Sensations...
Can I download to Phone instead of computer
And if not what real good ROMs can I download to my phone instead of using the computer?
My computer broke last night
You can download to your phone without a problem. I would say that you should do it while connected to Wi-Fi or lte. I wouldn't want to do it on 3g.
I've been trying to download the new gmail update. I keep getting the error message, "package file was not signed correctly. Uninstall the previous copy of the app and try again." Since it's a system app, I don't have the option of uninstalling in settings. I went to Titanium Backup, but it gives me a scary warning about uninstalling a system app. :) I'm running Up In Smoke, so I assumed the reason I was getting the error in the first place was related to not running the stock rom. Maybe that's not the case? Thanks for any help!
That's because you have a themed version of gmail. Look in the Kuban Updater and see if dazed has got the new one there yet and install from there. If he doesn't have it yet you can either wait for it or follow these steps to get the lame version...
1. using titanium back up uninstall the gmail app. Or go to system apps and delete the gmail.apk with a root file explorer such as root explorer or es file explorer.
2 Reboot to recovery, wipe cache and dalvik.
3. Restart phone.
4. go to playstore and install lame version. :)
By the way dazed is going to try and have the MB1 version of wicked out this weekend. No promises though.... It may come with the updated gmail app. So you might just want to wait... Just sayin....
Sounds good...I don't mind waiting. :) Thank you!
Skunk, clear something up for me. I've seen alot posts in other forums saying that the MB1 update was 4.1.2. Am I correct in my understanding that MB1 was a modem update and totally different from the Android Version?
It's a little more than just a modem update. It does update the Modem but it also fixes an overheating issue that MA6 Update caused. Plus perhaps a few other small changes. The android version is 4.1.2.
Status
tuananh3105
