[ROM][TORO] Paranoid Android [JellyBean][V 1.6][PreAlpha]
Re: [ROM][LINK][TORO] Paranoid Android [CM9HYBRID][V 1.4]
512 is for higher performance, 384 is better battery life regular performance.
Gpu stuff. :):)
Just flashed this again...currently restoring from market. Going to follow my own advice and give it a few days since I only gave it ~11 hours last time.
Questions..
(1) How does Nova work?
(2) How does Swype work?
Nova works perfectly. Just like the phone version.
Also I need help with my Google Music. It won't make the music I want available offline because I need to "check my Internet connection" when I saw this I checked if it would work on 4g and it did the same thing. What can i do to fix this? Music is no doubt the most important thing on a rom haha
Reactions: dmmarck
Nova's great...one complaint---Chrome. Is it just mine that the text size sorta stays small? How can I change that to a true mobile browser, not a tablet one?
I'll post a screen. Another issue...posting screenshots in the AC app...if using "Tapatalk" I get a wrong format error? (I don't get this with regular Tapatalk).
Do not want ^!
Also I have a question about Google Music. I have tried to make music offline on my phone and then when it says making music available offline, it says I need to check my Internet connection. So I tried 4g and it still is not working. Any suggestions on how i t Google Music to work?
Click to view quoted image
Do not want ^!
Side note: that whole status bar/nav bar combination is hawt.
Fair peoples of the Paranoid Android Rom:
Can someone tell me how in the hell to turn on vibrate only? I've literally sat here for 30 minutes trying to figure it out.
#mondayproblems
#mondayproblems
Have you held the volume rocker down. It should go into vibrate mode :thumbup:
BinaryCode transmission from ParanoidNexus via XpTapaTalk2
Have I ever :(
You try setting a toggle? Can't remember if its silent only or has option for vibrate.
Appears to be for silent only (the toggles are severely, severely limited). I'm going to break the volume down button at this point...lol
Vibrate is enabled in settings? Pulling at straws here...
I never use vibrate only, I do silent alot tho..
Thoughts? Vibrate and ring is the only thing with vibrate in it. I have to be missing something, right?
Sent from my TARDIS
Sent from my TARDIS
With this selected, and the volume turned all the way down, it doesn't maintain vibration? I'm surprised there isn't a volume, vibrate, and then silent (with the vibrate being an option in between the lowest audible sound selection and silent).
Like this?
I can link them, but same result.
Weird, isn't it?
Sent from my TARDIS
When you go up one from that, does it skip over vibrate mode that exists in stock?
That's just odd. Try a dirty flash of the from again. This doesn't make your problem go away but my vibrate seems to work fine. Thats why I asked about the rocker earlier. Just like zero said...I don't use vibe much anymore either.
Reactions: dmmarck
I'll just wait until 1.5 to be honest, it's supposedly coming out sooner than later.
Reactions: sicario666
Ruhanis
