- Nov 25, 2010
- 15,958
- 2,752
- 0
what exactly does Data Service Governor Killer do? is it an app or add on?
I have not used it but from what Ragnarokx said it has no real benefits that is why he didn't include it in TrulyEpic Rebirth.
Just in case anyone sees this problem, reflashing the ROM cures this problem. I think somehow when booting up the first time without the modem drivers installed can cause a issues.
I have the wi-fi error when I try to turn it on as well. Started having it back on "stock" DK28. Try to turn it on, long delay, finally reports "error" under the wifi settings screen. Not a ROM issue, but sure is annoying. i've just gotten used to it taking several attempts, eventually it works.
Haven't found any likely fix anywhere.
Sent from my SPH-D700 using Tapatalk
If you made a backup in CWM before you flashed the bootup animation then yes. Otherwise you will need to flash the ROM again.So I flashed a boot animation & I wanna go back to the one that originally came with the ROM. Is there a way for me to get it back without having to re-flash the whole ROM? :-\
You could try flashing the ROM as long as its the same ROM with NO WIPE and see how it works. If you have no FC's then great, otherwise worst case you have to wipe and flash again.
I have a question. On the lock screen under the time it says belongs to: How do I put my name in or what ever I may want to put there?
Are you referring to where it says TrulyEpic Rebirth on the lockscreen?
Hmm.. perhaps an app like Juice Defender would help in this situation. If Juice Defender turns off your WiFi every time your phone sleeps, and turns it back on when your phone wakes, this would essentially perform your fix but automatically (in theory - I don't remember if Juice Defender is capable of doing this).
Juice defender does turn the wifi on and off. Unfortuanely mine sometimes goes into a mode where "error" is listed under wifi settings screen. If I touch this menu item it normally is able to turn things back on. I actually think the error shows up more often using juice defender on my device. Have been using TER for about 2 weeks.
Dave
ragnarokx, This is hands down my favorite rom I have used to date. Including all of the EVO roms, and hero roms (No offence to any of the fine devs over in those respective forums), Keep up the great work!
Although i did have a few questions.
1. Is there a standalone flashable zip for the blue circle clock without the rest of the dark theme?
2. If so is there a flashable theme for the original theme as well?
3. I'm getting incredibly long boot times. Thought the boot animations are friggen awesome just sayin =P
4. Lastly i'm getting noticeable lag when switching between my home screens as well as whenever i try to open up the app drawer. Noticeable, but not a deal breaker.
Thanks a lot man! great work, keep it up!
This is not isolated to TrulyEpic Rebirth. My wife is running Bonsai on her phone and the same thing happens. I'm starting to believe the dialer pad isn't intended to show in landscape mode because it wouldn't fit the screen.Does anyone know if someone has fixed the issue with the epic dialer where the keypad disappears in landscape mode?
