[ROM]-[UPDATE-082112] Kool-Blue_2.3.3_V2.3
Status
Not open for further replies.
So your main sdcard partition is ext2 or 3? Hmm mine is fat32 with ext3 partition. For some reason it sounds like it doesn't like your partition. Did you partition it from recovery?
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.3 on LS670ZVJ Baseband
no i used mini home tool, main is fat32, then i have two other partitions, an ext2 and an ext3
16 g card
Ahh I bet that's why. I don't think I've heard of other people using 2 ext partitions. Have you had it work like that with other 2sd scripts
Everything working with sd-ext? and did your cell/data need a restart to work?
Well I actually needed two reboots to get data to work but it seems fine now :) and the sd-ext thing is a lot diff to me than what I'm used to... does it automatically go to sd-ext when you download an app? the only option i see under manage apps is move to sd card but in the sd card/storage menu it shows 1.64GB internal??
This script actually mounts /sd-ext as /data so as far as the phone knows your sd-ext partition is your internal for all purposes.
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.1 on LS670ZVJ Baseband
Ok, I'm actually getting a wacky 3G signal now... it worked for a while downloaded a couple apps, and now it's not working like it shows a 3g signal, but google isn't working and neither is play... any ideas?
I think i found a bug with the new script. Please check if maps/navigation work. For me it acts like it's working but where the map should be stays black. Let me know if it's the same for you guys.
EDIT: I reverted to a v2.2 nand and everything worked. Then restored my 2.3 nand and now it works... I guess I'll have to wait for someone else to try it and report back.
Just waiting on permission to release 2.4
Status
cinemacritic
