[ROM]-[UPDATE-082112] Kool-Blue_2.3.3_V2.3
Status
Not open for further replies.
On that note I'm releasing an update in a few min with all system apps and su binary updated and sprint update features removed from the about phone menu.
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.1 on LS670ZVJ Baseband
Re: [ROM]-[UPDATE-082012] Kool-Blue_2.3.3_V2.2
Update!!
About phone screen no longer has:
Update System
Update Firmware
Update Profiles
Update PRL
all these features were useless to us OV users and now they are gone :-). All system apps updated to latest version and SU binary updated to 3.1.1
Ok now I'm torn. Less then 24 hours ago I released an update and now I found a new script to utilize sd-ext and replace both the Dalvik2Cache mod and mount2sd script I'm using now. Should I wait till I have more to update?
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.2 on LS670ZVJ Baseband
I wouldn't mind if you updated... how many people use this rom? I haven't tried it yet
this looks nice! still pretty new to the ac forums and learning my v, but when i try to get the kernel it says not found 404 whatever. does anyone have another link, or is there another kernel that you recommend?
i would like to see 760 MB free!:)
thanks
thanks
Hlxanthus posted a link at the end of the hydrokernel thread. Team Hydro is changing servers and the new server isn't up yet.
V2.3 is up.
CronMod-INT2EXT+ script to take the place of mount2sd, dalvik2cache, and Zipalign scripts.
Please remember this does have a bug that will disable cell/data service untill after one reboot.
Flashed twice and on reboot my phone boots right back to recovery, any thoughts? Before your update it flashed and booted fine
What recovery? Do you have an sd-ext partition setup? Check the MD5 against the one on the op?
I'm thinking you don't have sd-ext setup and the new script demands it. If anyone else gets a chance to try. it'd help to figure out why.
Edit: ok just booted mine without my sdcard in to simulate not having sd-ext and got the same behavior. Backup your sdcard contents and in recovery partition your sdcard. (it will wipe your card clean) then restore your sdcard data after partitioning.
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.3 on LS670ZVJ Baseband
Status
liquidsnake757
