[ROM]-[UPDATE-082112] Kool-Blue_2.3.3_V2.3
Status
Not open for further replies.
Should I undo the blue theme and release it with stock colors on my next version?
Update: released V2.1 check the OP for link. New features are:
Amphetamines
New default wallpaper
New Boot.img
Apps2ext
Dalvik2Cache
Amphetamines
New Boot.img
Apps2ext
Dalvik2Cache
Where did u get dalvik to cache mod
Sent from my LG-LS670 using Tapatalk 2
Could you possibly make a zip files containing the files (not flash able)
Do you guys think this Tom is compatible with the lp506 with arjens gb kernel?
Sent from my LG-P500 using Tapatalk 2
I'm not sure why you posted this here? I just ment if you wanted to get the Dalvik2Cache Script its in the init.d folder of my rom...
Tapatalk'n it from my VM670 running http://forums.androidcentral.com/showthread.php?p=2062597
Kool-Blue_2.3.3_V2.1 on LS670ZVJ Baseband
Re: [ROM]-[UPDATE-081612] Kool-Blue_2.3.3
OP updated with Flashable Stock_UI theme and Kool_Blue-Theme. Just for those of you who wanted to try this rom but didnt like my blue theme. If anyone wants to make some flashable themes for this i'll add them to the OP as well.
If you could add the notification power widget similar to Hydrorom or Reborn and get MMS working both ways, that would be really cool.
I might be able to add the notification power widget but mms receiving is so far not doable. I'm looking into it the best I can in talking to other smarter ppl then me about this but it could take a while to figure that one out.
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.1 on LS670ZVJ Baseband
So I just wanted to make sure before I flash, that I can use this on my LG optimus v zv9 without any patches? just flash the zip like I would any OV rom?
Just disable signature check in recovery and flash away. I just don't know how to sign my zips yet
Status
liquidsnake757
