When you turn it off and turn it back on, does your OS detect new devices? Say in Windows it makes those insert and eject sounds?
Did you do a straight V007 install, or did you get to V007 through an earlier version?
That is correct also. It's just a paperweight now. I guess I didn't pray to the phone gods hard enough.
Try the kdp 500 utils and zefie's V9 cab. Maybe that will let you restore. Or you can retry the KDZ method with zefie's cab. I had issues with KDZ myself but the kdp500 worked perfectly and I was able to force flash V9 over my OTA VC and then update via lg tool. Now rooted again and workin like a dream![]()
Interesting. Can you post the kdp utils you used because all the ones I tried did not work.
Format the cache from recovery. Should get the market working.
I was having the same problem, so I formatted everything (even SDCard) other than boot and then reinstalled VCRom. Worked fine after that. I just assumed the cache was the problem since I tried everything but that before I formatted everything.
Has anyone that has had market issue just went into appliactions and cleared cache and data on market then tried? Maybe even try clearing the cache in applicatons before trying to install a app.
Tried and yet the X still appears. Maybe i'll try version 6 lol
adb logcat > logcat.txt
