[ROM] [VM701] Mobster Rom v1.4 update: 5/28
Re: [ROM] [VM701] Mobster Rom v1.2.5 update: 3/7
Hey! I got a theme for mdpi phones and i made it into a flashable zip... not sure if i can post it as i did not make it...
i haven't gotten any messages.... but im sorry you feel that way.... i made this Rom hoping to inspire others to use this as a base for their rom/theme helping the community.... its fine if you guys don't want to use this rom i do have other roms that i can be working on for the triumph i think my next release might be the last for a while....
@ jcole20 - This Rom's updater-script formats and mounts the system for you it isn't necessary to do it in the recovery but it wouldn't hurt
Personally I think this ROM is good and I think the camera tweaks are awesome! I really hope you continue upgrading this ROM and overpower Gelato. You seem very good at developing so that's something to have bragging rights for and to be better than some people. Please don't stop updating this ROM. The Slider community needs you.
EDIT: As for the other people, I'm bootlooping as well. Going to go ahead and flash stock and then flash this over that.
EDIT2: Another addition you can make to the ROM is removing the "Privacy" option under Settings to prevent inexperienced people from Factory Resetting their phone via that and risk a brick.
I like where this ROM is going... It's good so far, I haven't had the bootloop other people have had problems with. It did however take a good 10 minutes to boot the first time but I guess that's par for the course when flashing. Seems to be slightly better battery life, but the 135mb or so free is kinda iffy. Don't let people get to you. Thanks for the time and effort you're putting into this
Yeah, it's a bit troublesome when you're restoring lots of apps. But it's not really a problem if you have the time to keep pausing the restoring of the files to move them to SD etc.
I had to get rid of like 3 games and 5 apps just so the phone can stop displaying low on space. Ah well.
EDIT: Just found something out, after deleting all 3 bluetooth .apks using "SDX System App Remover", I now have 35MB free after rebooting. (If you decide to do this as well, it will keep giving you a "bluetooth blah blah closed unexpectedly" with the force close button that pops up right after you hit force close, so you need to hold down the power button to bring up the reboot option and keep clicking force close and then quickly hit reboot. Might take a few tries but I don't use bluetooth at all, so having the apk's needed for it is useless. Seems it gives me lots of space free anyways.
Thanks guys i should have a new build up tomorrow after i get out of school....
it should include the music/audio mods aswell as the privacy option removed from the settings.apk
Ahh yes finally gonna have better sound on the slider this is sooooooo exiting!!!!!! I can't wai!!! Keep up the good work bro!
okay?
status bar was themed. originally a metamorph.
Estabien if you theme the framework-res.apk that came with the working crt animation it will still work. Try rethemeing it. Or look up my walkthrough in the vm slider section and reenable it. They're build.prop is already set you just need to decompile the framewrok-res.apk, change the bools value to false listed in that walkthrough and then recompile (delete the resource.arsc from the keep folder when compiling), go to the unsigned .apk and copy the resource.arsc file out of the root of it and put it/replace it in the original framework-res.apk. Reflash and it's working.
I think the problem is that I used the framework-res from the first release of this rom.
I can easily fix that tomorrow... I can't get on a computer right now because its one in the morning and I have school tomorrow, but I can get on after school.
EDIT: Actually whatever, mania is awesome so I might as well embrace it. I'll work on it tonight.
Sent from me to the Internet to you...
here ya go... it works just fine x3
EDIT: onoez problems.
Hey guys i know this is the Optimus Slider forum but can i ask you guys for a favor..... can you sign these petitions to get Gingerbread on the Triumph i'd really appreciate it if you did :)
This one ask for 100 signatures the sooner the better :)...
Motorola: Update the Motorola Triumph to the latest Android OS.
This one would definetly have more impact asking for 20,000 signatures
Motorola: Upgrade Motorola Triumph To Gingerbread.
Done! :] and it can't hurt, I might want to get the triumph in the future anyways.
Reactions: Mobstergunz
Installation Instructions:
1 Backup
2 Wipe Cache
3 Wipe Dalvik Cache
4 Install ROM
5 Reboot
If I already have GingerKernel installed, do I need to flash it again after installing this ROM?
(I've been running Gelato 11-28 with GK)
my assumption is yes this Rom comes with its own kernel that overwrites what you have now..... flash GingerKernel right after the rom and you should be good :)
Reactions: Bigtuna00
Re: [ROM] [VM701] Mobster Rom v1.2.7 update: 3/9
New Update to V1.2.7
this should add :
Notification Toggels
Privacy Removed from Settings
enjoy:)
Aruz530
