No problem... id use the dsp manager from cm7 I can link you to a working version for these phones.. (I use it on mine). The beats audio app is no different, but sounds so much better because of the beats audio headphones. Though the difference is no more than eq changes... the beats audio apk does nothing more than apps available on the market. Adding dsp in will give people more play with the overall sound of their device. As it adjusts headphone sound, speaker, etc. Id put titanium backup, dsp manager, and flash into the /data/app folder. That way its installed as a user app. I suggest putting the team hydro gelato kernel in as the boot.img. Enable the crt animations on screen off. Try maybe enabling tether on the build.prop change the tether.denied value to false. Make sure a2sd is enabled and walk people through setting up a partition. Maybe use some init.d tweaks but id be weary without being able to test them if I were you. What works on one phone doesn't work on all. The poweroff.apk has the shutdown animation you can edit it if you'd like. Id try to remove ciq but if you can't test it be very careful with that as well since ciq is deeply ingrained into the rom and its hard to deactivate without causing force closes. If you shoot me the framework-res.apk and systemui.apk ill try to set you guys up a theme for the phones to match the name. Hope this helps though you probably know all of this.
Sent from my LGL55C using Tapatalk
