[ROM] Wicked Sensations for the Sprint GS3
Status
Not open for further replies.
Lf9 has worked best for me. But I'm not fortunate enough to have lte yet.
Sent from my SGS3 while experiencing some Wicked Sensations?.
is there a real way to see which one is better for you or do you just have to pay around with it and see which ones better for your signal and battery life? Right now I'm on lg8. Thinking about trying lf9 but I probably won't see a difference because I don't pay that close attention to detail so unless something tells me it's better then I'll probably just stick with lg8
It's different for every one so what works for me may be worse for you. You just have to try each one for few days and see how your phone and battery responds. If your not having any problems with lg8 you might as well stay with it unless you just wanna play around with it.
My link is good.... It is on the server side or a error in the xda threads link. There are several messages for dazed there. So it will get straightened out tomorrow.
It must have been a problem with the server. I tested the link this morning with stock browser and it downloaded and flashed just fine. So if you had problems before, maybe give it a try again. Thanks.
Yup... Link in the OP has be reactivated...
Just flashed on my s3...works great, no probs found. Only thing I would like that I can't seem to find right now is making Google now appear on the lockscreen,
I guess I still have some learning to do, because I was thinking Google now would answer the same questions like S Voice did...but it doesn't respond to the silly questions you sometimes are mistaken for asking with S Voice. Is GNow an add-on for this ROM, or is it streamlined into it? I'm guessing it's a JB feature and isn't streamlined, so to speak?
True, any TW based rom with Google Now would be a modification.
Hey Skunks,
I had "Android lost" on my phone, but since the flash, I just noticed, nothing works.(from android lost that is)
Any thoughts?
Status
jmyoung48
