[ROM] Wicked Sensations for the Sprint GS3
Status
Not open for further replies.
so after installing this rom, do i need to install the removed apps download?
Just wanted to say that I went back to this from after trying ones that had big time flaws. After doing so it made me REALLY appriciate this one. The new version is AWESOME!! Good work!!
Like i said, "If you want a Rom that just does what it's supposed to and looks great while doing it, this is it."
well i installed this rom, and now my sd card is working. It prepares, but it shows nothing is on it, if i hook up my phone to my pc i can see everything on the sd card but it states theres no space left
How big is your card and did you format it since you bought it?
2gb and i formatted it before i rooted.
I unrooted and went back to stock, and now the card works again, and my pictures open up
Ill have to retry this rom again in the future, when i figure this phone out some more, i just got it yesterday
I liked the backround of the naked chic in the water, very nice Touch
I just hate all the garbage Sprint puts on these phones at stock
Did you format the card with your phone? Or did you format to exfat file system? If your answer to either of these questions is yes. That is your problem.
Yeah i formatted with my phone, now that its working, should i try it again, or maybe ill wait til the iphone 5 comes out to see if i want to trade in for that instead.
That's your problem... this phone formats to exfat file system but the phone has problems reading exfat. On your laptop it needs to be formatted in either fat32 or fat16. Then you will be fine. I will post a link to a file formatting program that will get you going later when I get home.
You are not on a phone forum, you're on android forum. Iphone talk is barely tolerated. Only criticism of the iPhone is allowed.
Reactions: dazednconfused1144
Do not format your card with the phone. Use a program from your laptop.
Download EaseUS Partition Master Install it on your laptop and use it to format your card to fat16 or fat32. It will fix your memory card problems for good.
Oh... BTW... Do you have [redacted] installed on your phone? If so it will also cause your memory to show full when it's not.
sorry i didnt mean to offend anyone, and i wasnt threatening of buying a iphone. Ive never owned anything apple in my life so i dont think i would start now.
I will def give wicked another go after i format my sd card the right way.
My only gripe with this phone is the huge screen is hard to hang onto with one hand and trying to text. I love the resolution though and the pics and vids are insane.
Im a t9 texting fanboy.
Does wicked have a t9 keyboard, and can you add words
Ive noticed with stock it has the t9 keyboard but you cant add words, or type individual letters
I think as far as the T9 keyboard goes, you would need to download one from the Play or Amazon App Store.
And as far as one handed texting, I have one of these...
Flygrip - Navigate your Smartphone with One Hand
It's a bit pricey, but I love it.
I have tried to flash some mods and it doesn't seem to be working. I go into cwm, flash the zips and reboot the phone. Is there something I am missing here?
Which mods are you trying?
Im back to wicked, and everything is working smoothly, thanks.
But couple questions,
What exactly does the add ime option do for the keyboard, after i flashed the wicked rom, i looked at the keyboard, and then i flashed the add ime option but nothing has changed.
What exactly does it do?
And how come when using google now, you have to use the home key to get out of it, you cant just exit it by pressing the back button?
The ime option adds a shortcut to the notification bar when you are typing. It will allow you to change the keyboard without having to go into the settings menu. For it to show up while typing, I believe you must have more than one keyboard installed and setup.
As for Google now, it still has a few bugs when used with ICS. I don't particularly like it (google now).
so as far as updates go, do i have to wait til you update your rom with current updates, like google now, or firmware updates?
Whats a good keyboard that uses t9, right now i only have the android keyboard from wicked, and i hate typing individual letters
Status
doxidex23
