[ROM] Wicked Sensations for the Sprint GS3
Status
Not open for further replies.
Hey Skunks,
I had "Android lost" on my phone, but since the flash, I just noticed, nothing works.(from android lost that is)
Any thoughts?
android lost is awesome. Make sure it's still a device administrator since you flashed the rom
Is there an "update" to install over 1.0 or do I have to reflash 1.1? I just got through setting up this one last night and don't really feel like doing it all over again so soon.
I was also going to ask if anyone has done any comparisons between this one and Blazer. Love the theming on this one, I wasn't sure how it stacked up battery life, speed, etc.
It looks like the Battery mod changed with 1.1. Is it possible to get the one back that was in 1.0?
Is there a way to change the default input method (like while typing a text msg) without backing out of the message app and going into the main settings menu to get a different input method? (like going from Swype to another keyboard, in the middle of typing a text message, instead of having to switch by going all the way to the main menu from the home screen -- or pulling the notif bar down and going into settings that way?)
I have added the IME Switcher to the mods in the 1st post. Or you can download it from HERE. Just flash in recovery and you're all set.
Thanks Dazed! You are on it!
Reactions: dazednconfused1144
Hi most of you around here who know me, know that I would never suggest a ROM that I wouldn't run myself. This is my daily driver. If your main concern is a rom where everything just works, You owe it to yourself to try this one out.
TeamVenum and dazednconfused (the creator of Wicked Sensations) have graciously allowed me to host this thread here on Android Central. I am here to run this thread and answer questions and provide help if required.
Bugs and Requests:
I will provide Dazed spreadsheets on any bugs or issues that are found. And also provide a user request to him daily.
Dazednconfused's Wicked Sensations official thread
Please don't report know issues.
KNOWN ISSUES:
1. Hot Boot in the restart menu doesn't work. Don't try it.
2. White square around microphone in Google Now. Fixed In V.1.1
Changelog:
v.1.1
-1. Cell Standby Fix added
-2. Added MMS Screen on/off notification option - Thanks freeza
-3. Removed Battery Full and Screen on not. - Thanks clark44
-4. Updated apps that had updates.
-5. Added themed XDA app (free version)
-6. Removed Samsung keyboard and add themed LatinIME Keyboard - Not sure who themed it, but if you let me know i will definitely give thanks. Its awesome.
-7. Removed notification that pops up when you plug in headphones. - Thanks clark44
-8. Fixed and cleaned up some theming in Rom.
-9. Themed Pattern Lock Screen to blue instead of green.
-10. Added No Wallpaper option apk.
-11. Themed TW Launcher and Folder per request.
-12. Updating all Mods.
-13. Fixed YouTube like/dislike buttons
-14. Add mod to use Volume keys as Shutter in Camera - Thanks freeza
-15. Themed Camera - Thanks joshbeach for letting me use some of your images.
v1.0 -- So please let me know if you find anything.
Unless Otherwise noted. All Mods and Fixes are installed using instructions below.
-1. Download zip and place on sdcard.
-2. Boot into recovery and flash zip.
-3. Reboot and enjoy.
Quick Fixes:
None At this Point.
Mods All Mods Come from dazednconfused XDA Thread Found Here
Remove Camera Shutter Sounds Only
Remove All Camera and Camcorder Sounds
Restore All Camera Sounds
Wicked Themed MMS Screen on Fix - Huge thanks to freeza. Mms fix that gives you the option to disable the screen turning on when you recieve a text. If you lose the stock wallpaper after this mod, they are at the bottom attached to this post.
Call Recording On This will disable the Swap Calls function
Call Recording Off
IME Switcher Swap keyboards on the fly.
Battery Mods
Click Here
HoneyComb Battery
Click to view quoted image
Click Here
Click Here
Click Here
Click Here
Click Here
Add the Wicked Pull Down with your Battery Mod​
Confirmation. ..this is the most amazing rom
Sent from my SPH-L710 using Xparent ICS Tapatalk 2
Flashed a few days ago and really liking, but I miss Google wallet. Is there an easy way to make it work instead of getting the unsupported device error?
Thanks keep up great work!
Thanks a lot, appreciate you saying that. Had a lot of help from some pretty amazing people to get it all together. Glad your enjoying it and let us know if you have any issues.
dazednconfused has posted a good amount of mod for this rom. I will try and get this thread updated this weekend!!!
Reactions: Uncle Louie
Thinking about going to this after running paranoid for some time now. A quick question... I like the drop down menus from jellybean. The ones that show more info. How close are you from having this feature or is it even possible??? I just can't handle some of the none working issues. ;-) ;-)
Sorry I am told that it is not possible on ICS. On the bright side, JellyBean should be coming before we die of old age.;)
Reactions: brackett5
Just wanted to say that I went back to this from after trying ones that had big time flaws. After doing so it made me REALLY appriciate this one. The new version is AWESOME!! Good work!!
Status
doxidex23
