[ROM] Wicked Sensations for the Sprint GS3
Status
Not open for further replies.
When I scroll to a screen other than the home screen and press to home button to go directly back to the home screen it doesn't work. It just pulls up a list of all my screens and then I have to press the actual home screen to get back to it. This also happens when I am in the app drawer as well. Its very annoying, using nova launcher
If you are using nova launcher you go into nova settings/gestures and buttons. Then set it up to go to default page.
Do I need a nandroid backup and titanium backup as well?
Ok, so...basically I did both, but I forgot to do a wipe/factory reset. When I installed the rom and booted up my phone, everything was working well. All my apps, contacts, media, pictures are still there. What is the purpose of wiping your phone?
ALWAYS do a nandroid, just in case you need to go back in case of a bad flash. As far as Titanium goes, I only backup apps, as restoring system data can cause issues when changing ROMs. Titanium Backup isn't a requirement , as long as you don't mind starting fresh.
Titanium backups work fine for just backing up apps. nandroid is for backing up your entire system.. to include everything from rom, kernel, passwords, wallpaper, homescreen settings. when you restore a nandroid, it's like going back in time.
---------- Post Merged at 10:42 PM ---------- Previous Post was at 10:38 PM ----------
How come I didn't see this post. it sure as heck wasn't there when I started....:p
It's MAGIC! BWAHAHAHAHAHAHA! :D
love this ROM. I am getting a software update message from Sprint while running this ROM, guessing it's the 4.0.4 update. What happens if I do the update? It won't go away no matter how many times I say install later and it's driving me nuts.
Tell it to install. It will boot into recovery. Then verify you want to install it. It will fail. Restart your phone and it won't come back.
nice rom one ? tho i flashed it soon as the phone rebooted it gives the notifaction that sprint optimizer forsce close and phone freezes for a sec? any answer for that
Never happened to me and I've never heard it happening to anyone else until now. Most people turn that off anyway. Does it happen every time you reboot or did it just happen the one time?
I must say a very amazing rom
Im usually very picky about them,
i didnt like it at first. but it grew on me.
and i love it now
extremely stable, and the blue gives my phone some personality :p
my only issue which is minor is even when i have phone on silent, and turn off shutter sound. it stil makes the shutter nosie.
any fix or workout around?
thank you
and i love it now
thank you
Did you flash the silent camera mod found in the 1st post?
Status
Apexmaster40
