Check other people's set ups here:
http://forum.androidcentral.com/opt...344-measure-your-battery-life-brag-about.html
and here:
http://forum.androidcentral.com/opt...attery-drain-optimization-tests-part-2-a.html
Oh cool, ty very much
and here:
I have the same issue.
this is my first try and so far the flashing went ok from what i can see but i hava few problems
1verclocking really dose not work i crash a lot lol @787 and above i would like to go higher
2:my camera works but as soon as i take a pic or start to record video it gets laggy then i get a force quit its pissing me off i take a lot of pics
should i jusr relflash to see if it fixes the problem ... ?
and if do reflash how would i go about doing so just go into recovery then flash again .?
Cant help ya there having same problem.cashmonkey said:Couple questions.
1. The button remapper software I installed doesn't work (freezes phone). Which app are you guys using, and what key should I remap? The long press search doesn't pull up voice search. Right now, it pulls up the messaging ap.
Check out this thread.2. Are there any Circle Battery Mod's for this rom?
3. Where can I find other Metamorphs, or themes? (I see there is a theme manager in this rom)
You can use any launcher you want. Just make it the default after installing and hitting the home button and the pop-up asking what you want to use for this task.4. Is there a mod to put always have the date on the top left corner
5. Can I remove the standard launcher and use launcher pro? (I was thinking of renameing launcher.apk to .backup or something.. is that OK?)
Thanks
Any chance of getting this ROM (and phone, actually) supported on ROM Tools?
It'd make a HUUUUUGE difference, in my opinion!
Couple questions.
Thanks
Yes go back into recovery and do a wipe and re-flash (if it makes you fell better)
But that will not fix your overclock - some phones have a higher ceiling then others so don't get your hopes up.
lol What? ROMtools works and has been working for me since I bought the phone! Are you new here?If you are, then do some research before you do anything to your V. Peace~
